Curves workbench
Vincent B
Re: Curves workbench
Post by Vincent B »
This JoinCurve have a BopAlgo GeomAbs_C0 error.
That's give the same error to surfaces. How to avoid that?
JoinCurveBopError.FCStd
(6.62 KiB) Downloaded 71 times
Chris_G
Post by Chris_G »
GlouGlou wrote: Sat Mar 07, 2020 3:27 pm This JoinCurve have a BopAlgo GeomAbs_C0 error.
BopAlgo GeomAbs_C0 is NOT an error.
This is just an information message.
A curve or a surface with C0 continuity is valid.
I think one reason why a C0 continuity is reported is that Offset fails on C0 surfaces.
(Maybe some other algorithms fail on C0 continuity too ?)
If you want higher continuity :
- select joinCurve
- set "Shape Approximation" active
- deselect joinCurve
- select it again
- some approximation properties will be available
Post by Kunda1 »
Post by Kunda1 »
Kunda1 wrote: Sun Mar 15, 2020 11:45 pm Note: several tasks could use some attention:
Wiki pages to be populated:
Curves IsoCurve
Curves ParametricComb
Curves ParametricSolid
Curves PasteSVG
Curves SketchOnSurface
Curves JoinCurve
Curves SplitCurve
Curves ZebraTool
Fixing some flagged LGTM alerts: https://lgtm.com/projects/g/tomate44/Cu ... &severity=
It would be awesome if we could document Curves before 0.19 is released...any thoughts ?
Post by Kunda1 »
So far we have some info for
Curves IsoCurve
Thanks to @GlouGlou
Post by Kunda1 »
Lets continue with documentation of the workbench.
soaring
Post by soaring »
Kunda1 wrote: Fri Mar 27, 2020 6:11 pm Lets continue with documentation of the workbench.
thank you for your work !
bavariaSHAPE
Post by bavariaSHAPE »
To give me an overview of the extensive Workbench, I have summarized the current functions in a document.
Maybe it will be useful for one or the other.
There is a lot to do for the Wiki documentation.
Curves-Toolbar.svg
(66.92 KiB) Downloaded 83 times
Curves-Toolbar.pdf
(45.71 KiB) Downloaded 162 times
… for a happy FreeCAD-World … JM2C …
Post by Kunda1 »
bavariaSHAPE wrote: Fri Apr 03, 2020 7:29 am o give me an overview of the extensive Workbench, I have summarized the current functions in a document.
I've added some the descriptions to the pre-existing placeholder tool pages for Curves WB documentation on the wiki. I also migrated several more icons to the wiki today.
bavariaSHAPE wrote: Fri Apr 03, 2020 7:29 am There is a lot to do for the Wiki documentation.
The struggle is real ;) But together we overcome it.
Post by Kunda1 »
What's the preferred order (chronological?) to link the Curves Workbench commands to each other in the {{Docnav}} template? In other words, pagination.
Chris_G wrote::bell:
Edit: also @Chris_G would it be possible to structure the Workbench the way @vocx and @carlopav are doing so for Draft ? In other words, move the python files outside of the top directory in to their own source directory. This would be wonderful to do pre-release (whatever we're calling it).
