Curves workbench
Re: Curves workbench
...first try => it looks a little bit weird
...PipeShell apparently does not like the "Slot-Feature" in sketcher.
I used an actual example out of the german forum. (flattened pipe)
Using only circles in sketcher the feature works as expected and parameters can be explored.
Sorry for the bad start.
- Diffusor.FCStd
- FC.17.13354
- (13.31 KiB) Downloaded 97 times
...and it works with BSplines .
Is it also usable with open profiles?
- Hull_PipeShell.FCStd
- FC.17.13354
- (46.05 KiB) Downloaded 134 times
It is usable with open profiles.
It is a "Part.Sweep" with more options.
So it should be able to do everything Part.Sweep can do.
I don't know if this tool will be really useful, but at least, it offers an easy way to explore the different options.
- Stéphane Combet
Wow, what an incredible work here!
I've installed this WB.
But: I am new in FreeCAD world, and I've seen screenshots here and there with other amazing curved stuff, and I wonder : do I need this WB to my project? Or is there something simpler in my case? And, I am with v16, I heard v17 does more with curves but are there commun points/differences with your great Curves WB?
Thank you!
(my project: molds for a personnal RC sailplane, https://forum.freecadweb.org/viewtopic.php?f=12&t=26757)
Thank you!
Hello,Stéphane Combet wrote: ↑Fri Apr 27, 2018 12:46 pm I've installed this WB.
The workbench is not tested with 0.16, and I know some tools won't work with this version.
I'll go there for further discussion.Stéphane Combet wrote: ↑Fri Apr 27, 2018 12:46 pm (my project: molds for a personnal RC sailplane, https://forum.freecadweb.org/viewtopic.php?f=12&t=26757)
Just played a little bit with "sketch on surface", immediately coming up with a question.
How should a sketch looks like, to fit onto a cone?
outline didn't fit to cone's face. Seem should be a straight line, shouldn't?
file:
file:
Every surface in FC (and I suppose this is the same in every CAD software) has a rectangle topology: its parametric space is a rectangle that goes from (u0,v0) to (u1,v1).
Cone.Shape.Face1.ParameterRange
>>> (0.0, 6.283185307179586, 0.0, 107.70329614269008)
Then set to True the properties "Construction Bounds" and "Scale" of the Sketch_on_surface object. In your cone example, you'll see that the upper edge of the bounding square degenerates to a point ( the tip of the cone ).
- WrapOnCone-2.FCStd
- (14.07 KiB) Downloaded 80 times
Oh, yes, i see.
Many thanks for clarification!
Unfortunately its a non conformal transformation , even if surface is developable.
Some support also spherical/polar coordinate systems. this can probably change the results of that kind of curves...Chris_G wrote: ↑Sun Jun 24, 2018 8:18 am Every surface in FC (and I suppose this is the same in every CAD software) has a rectangle topology: its parametric space is a rectangle that goes from (u0,v0) to (u1,v1).Code: Select all
Cone.Shape.Face1.ParameterRange >>> (0.0, 6.283185307179586, 0.0, 107.70329614269008)
