Curves workbench
Re: Curves workbench
Everything work OK here.
When you select 2 edges and activate the BlendCurve tool, a BlendCurve object is created, but the 2 input edges are still selected.
Are you sure you clear the selection, by click somewhere in the 3D view, before going for the second BlendCurve ?
Clicking in the 3D view does not clear the selected curves. I still see curves selected once I click. Could it be a preference setup?
Chris,
Just figured it out by accident. Setting Navigation Style to CAD will fix the BlendC_Curve issue. I had somehow set my Navigation Style set to OpenInventor. My previous thread of Gordon might be related to this as well...will check it out later.
Thanks for the support.
… some post before we talked about IsoCurve concerning GlouGlou's definition.
https://forum.freecadweb.org/viewtopic. ... 70#p342960
Defining wing profiles there exists the so called "camber line":
https://en.wikipedia.org/wiki/Camber_%28aerodynamics%29
I made different tests, generating such camber lines and got good and weird results.
https://forum.freecadweb.org/viewtopic. ... 26#p343870
Does the code the correct calculation?
IsoCurve could be the tool to reproduce camber line on existing profiles, for getting a feeling of profiles curvatures.camber line, the curve Z(x) that is halfway between the upper and lower surfaces
- AirPlaneDes_2.FCStd
- (37.39 KiB) Downloaded 54 times
CurveOnSurface:
Each time the curve reach degree 14, it give some errors.
Is it possible to limit the degree of the bspline?
- truc7.FCStd
- (77.58 KiB) Downloaded 42 times
- Capture.PNG (43.5 KiB) Viewed 1572 times
Well ... the curve is definitely not on the surface.
The curveOnSurface tool is not a projection tool; it only uses a projection fallback for some tricky situations.
The curve is supposed to already be ON the surface.
ok, i thought this tool was planned to do that as well to carry out a cladding (plaquage en francais)
- Capture.PNG (79.66 KiB) Viewed 1490 times
- truc9.FCStd
- (161.19 KiB) Downloaded 45 times
Could you make an option to reverse the U and V coordinates?
thanks a lot.
thanks a lot.
- truc10.FCStd
- (119.54 KiB) Downloaded 43 times
- Capture.PNG (122.25 KiB) Viewed 1484 times
Thanks a lot!Finally,I solved it.Now,I have another question.How do I export a curve into mesh(.obj)?The emphasis is on curves and obj formats!Hope your reply.
