Curves workbench
GlouGlou
Re: Curves workbench
Postby GlouGlou » Thu Nov 29, 2018 8:17 pm
I'll check out that very closeley, thanks
Chris_G
Postby Chris_G » Fri Nov 30, 2018 8:14 am
GlouGlou wrote:
Thu Nov 29, 2018 6:50 pm
How I can use Gordon feature for this kind of shell. I've tried with "Fill boundary curve" from "Surface WB", but you can see the surface is not following profiles very well. I've tried your Gordon tool as well but without expected success.Thanks.
Gordon surface works with a curve network that must look like a grid. That means 2 groups of curves (the profiles and the guides) :
- inside a group, curves must not intersect or touch their neighbours
- each curve of a group must intersect every curve of the other group.
TopTest-2.FCStd
(73.36 KiB) Downloaded 11 times
freecad-heini-1
Postby freecad-heini-1 » Fri Nov 30, 2018 8:51 am
Hi Chris,
thank you very much.
I mirrored the face:
Will there be any possibility for the future to define it tangent or perpendicular to the neigbor face?
Best regards
Wilfried
Chris_G
Postby Chris_G » Fri Nov 30, 2018 10:26 am
Hello Wilfried,
I don't know. That's not an easy task.
But I agree that it would be pretty useful.
hammax
Postby hammax » Fri Nov 30, 2018 10:32 am
… my favorite is the "SplitCurve" idea, in case of already existing wires.
Chris_G's example must be redigested and shortened to see the clever workflow.
microelly2
Postby microelly2 » Fri Nov 30, 2018 11:09 am
Hello Wilfried,
the tangents on both sides of the top control point must be parallel, in the simplest case they can be horizontal.
if you look into my examples you see in the sketches parallel contraints. these constraints force the surface tangential smooth G2.
the same holds for the curves on the bottom area.
hammax
Postby hammax » Fri Nov 30, 2018 11:14 am
… the fault when mirroring (hamburger groove) maybe is a product of the Gordon algorithm.
In this case it is only near the split points of the circumference wire.
GlouGlou
Postby GlouGlou » Fri Nov 30, 2018 8:13 pm
Thanks a lot, i'm trying to make this exercice:
https://apprendre-la-cao.com/dessiner-u ... -catia-v5/
and trimmed face is working! ;)
arrosoir.FCStd
(312.55 KiB) Downloaded 9 times
GlouGlou
Postby GlouGlou » Sat Dec 01, 2018 4:51 pm
I finished this watering can using Gordon, Pipe Shell and Trimmed Face. Give me flowers :lol:
What about the fillets and offset3D improved? Could be the next tools? :roll: :roll: :roll: :lol:
hammax
Postby hammax » Sun Dec 02, 2018 11:43 am
… a question concerning the SplitCurve tool.
If I apply the SplitCurve I get a point on the chosen (percent or else) partition.
Selecting the sections they get highlighted.
But the splitted curve itself still acts as a whole.
To get separate sections, my workaround is Discretized_edge and rebuild it by interpolate points.
A little bit complicated and overdone.
Is there a more elegant way, getting sections for Gordon surface?
