Curves workbench
UR_
Re: Curves workbench
Postby UR_ » Sun Dec 02, 2018 12:02 pm
Have you tried this?
Edit: If you prefer the parametric way, Lattice2WB "Explode compound" should be first choice
Lattice2 WB Explode Compound.PNG (2.11 KiB) Viewed 590 times
paullee
Postby paullee » Sun Dec 02, 2018 2:58 pm
Hi, I just try creating BSpline curves and find only straight lines on screen.
Found some message in Report View
Unknown command 'Curves'
HUD init
Cannot compute Inventor representation for the shape of BSplineCurve001.
Any idea what is wrong?
FreeCAD_0.18.15287.glibc2.17-x86_64.AppImage
on Fedora 27
Screenshot from 2018-12-02 22-57-42.png (155.68 KiB) Viewed 572 times
Test_ CurveWB_ BSpline_ 01.fcstd
(3.58 KiB) Downloaded 6 times
Chris_G
Postby Chris_G » Sun Dec 02, 2018 3:29 pm
hammax wrote:
Sun Dec 02, 2018 11:43 am
… a question concerning the SplitCurve tool.
If I apply the SplitCurve I get a point on the chosen (percent or else) partition.
Selecting the sections they get highlighted.
But the splitted curve itself still acts as a whole.
To get separate sections, my workaround is Discretized_edge and rebuild it by interpolate points.
A little bit complicated and overdone.
Is there a more elegant way, getting sections for Gordon surface?
I added an "Output" property that let you choose "Start","End" or "Wire" for the output shape
Chris_G
Postby Chris_G » Sun Dec 02, 2018 3:36 pm
on Fedora 27
This tool is rather unstable.
At the beginning, it creates a degree-1 curve, that looks like a polygon.
So it was needed to increase the degree while creating the curve.
I just pushed some changes to it. Now the degree is automatically increased to 3.
Please update the workbench and try again.
paullee
Postby paullee » Sun Dec 02, 2018 4:02 pm
Thanks! It works now!
Anything to do to change the 'degree' of curve? See no property in the combo view.
I am reading some wiki about spline to understand more about its nature and explore more of Curve WB.
Screenshot from 2018-12-02 23-59-22.png (157.25 KiB) Viewed 552 times
Chris_G
Postby Chris_G » Sun Dec 02, 2018 4:38 pm
Instructions are supposed to appear both in the upper left corner of the 3D view, and in the report view.
You should enable the 2 "redirect python output" options at the bottom of Preferences -> General -> Output window
Bezier curve controls are :
Left Mouse Button : add pole
Del : remove last pole
I / D : Increase / Decrease degree
Left CTRL : snap (works pretty bad)
Enter : Accept
Esc : Abort
paullee
Postby paullee » Mon Dec 03, 2018 1:08 am
Enter : Accept
Esc : Abort
I tested the functins and seemed not working as I saw only polygone rather than spline!
Now I/ D works as explained, thanks!
Del doesnot work very good - on my system, press it doesnot del the last pole, it keep on let me to add next pole, but then enter return nothIng and no polygon or spline.
Hope anythinh else could help debug.
hammax
Postby hammax » Mon Dec 03, 2018 6:29 am
SplitCurve:
https://forum.freecadweb.org/viewtopic. ... 70#p271829
https://forum.freecadweb.org/viewtopic. ... 09#p271871
… now it works and is understandable.
Thanks a lot.
hammax
Postby hammax » Tue Dec 04, 2018 7:11 am
… having fun with Gordon surface.
Getting tangential at the rims of the surface is an early task of the frame sketches, by applying tangential construction lines.
https://forum.freecadweb.org/viewtopic. ... 70#p271372
Mirroring without "corners / edges / grooves" seems to be possible.
Then you get a hull comparable to lofting, as the section lines show.
But there must be a separate "front shape", to close the hull.
BTW: could there be a way, to degenerate the "front frame" to a point,
so that the Gordon algorithm takes this point as a rim-profile (using a triangular shape instead of rectangular).
Something that emills did in his SilkWB?
SplitCurve_2.FCStd
FC.18.15316
(406.32 KiB) Downloaded 18 times
GlouGlou
Postby GlouGlou » Sun Dec 09, 2018 12:10 pm
Ive got a small bug with IsoCurves. Some curves are missing but got some plots instead.
siege.FCStd
(73.72 KiB) Downloaded 11 times
