Curves workbench
Chris_G
Re: Curves workbench
Postby Chris_G » Sun Dec 09, 2018 6:50 pm
GlouGlou wrote:
Sun Dec 09, 2018 12:10 pm
Ive got a small bug with IsoCurves. Some curves are missing but got some plots instead.
Indeed.
I have not looked at this code for a while.
I'll try to fix this.
Thanks.
GlouGlou
Postby GlouGlou » Mon Dec 10, 2018 8:20 pm
this surface give errors as well.
isocurve_error.FCStd
(118.95 KiB) Downloaded 7 times
GlouGlou
Postby GlouGlou » Tue Dec 11, 2018 8:07 pm
1.PipeShell with Frenet property is different with a part's sweep. Its seems not working.
2.when im moving PipeShell (x for example, the surface change)
FrenetOrNot.FCStd
(167.97 KiB) Downloaded 8 times
Chris_G
Postby Chris_G » Tue Dec 11, 2018 8:39 pm
Frenet mode offers a "Corrected" property.
If it is set to True, you get the same result as Part.Sweep
Probably a bug that I need to investigate.
Thanks.
GlouGlou
Postby GlouGlou » Thu Dec 13, 2018 8:55 pm
How to make a full Gordon instead an half one?
Or how to make a mirror copy?
HalfGordon.FCStd
(63.48 KiB) Downloaded 16 times
hammax
Postby hammax » Fri Dec 14, 2018 6:24 am
… look here:
https://forum.freecadweb.org/viewtopic. ... 25#p274225
and here
https://forum.freecadweb.org/viewtopic. ... 38#p272600
A mirroring with DraftWB was possible, but I also don't understand, how it works.
https://forum.freecadweb.org/viewtopic. ... 98#p274212
How do I get the coordinates of the normal vector on the mirror plane?
HalfGordon_2.FCStd
FC.18.15380
(108.72 KiB) Downloaded 9 times
hammax
Postby hammax » Sat Dec 15, 2018 4:12 pm
… I think that I found the hint to the mirror plane normal.
DraftWB uses the mirror tool of PartWB.
But PartWB mirror only can use the system planes or offsets to them.
In DraftWB you can generate a "working plane proxy" on the "surface for mirror".
When using DraftWB mirror you only are able to select 2 points on a wire of the "surface to mirror".
And you get an oblique mirror of the Gordon surface.
But inserting/using the values of the normal-vector of the working-plane-proxy into datatab of the mirror,
the oblique position can be corrected.
(A bug or a feature?)
HalfGordon_2.FCStd
FC.18.15380
(113.23 KiB) Downloaded 8 times
GlouGlou
Postby GlouGlou » Sat Dec 15, 2018 5:49 pm
I finally found a solution using PartDesign with datumpoints. Delete the constraint3 and move datumpoint001, we can see what is "normal": a vector that's must be perpendicular of the mirror.(of course).
MirrorSolution.FCStd
(152.78 KiB) Downloaded 5 times
GlouGlou
Postby GlouGlou » Sat Dec 15, 2018 6:11 pm
Here the same thing without PartDesignNext (Point is not a dynamic objet here)
MirrorSolutionWithOutPDN.FCStd
(109.02 KiB) Downloaded 11 times
GlouGlou
Postby GlouGlou » Fri Jan 04, 2019 5:04 pm
Interpolate_curves or Approximate_points carry out a wrong result when vertex are not correctly ordered. :o
VertexWrongOrder.FCStd
(6.55 KiB) Downloaded 6 times
