Curves workbench
freecad-heini-1
Re: Curves workbench
Postby freecad-heini-1 » Wed Mar 06, 2019 10:04 am
Chris_G wrote:
Tue Mar 05, 2019 2:49 pm
It should now work with individual faces.
Hi Chris,
thank you so much for your great work.
It's a pitty that reflect lines are not supported by Loft, Sweep and ruled Surface.
I have to convert it to JoinCurve.
Testobjekt_silhouette_trimmen_reflectLines.FCStd
(157.61 KiB) Downloaded 26 times
Best regards
Wilfried
m.cavallerin
Postby m.cavallerin » Sun Mar 10, 2019 7:50 pm
What tool to close the end of a wing?
I tried to use Sweep2Rails, but it doesn't work.
Also Gordon can't be defined.
Can someone give me suggestion?
Thanks
Regards.
Screenshot from 2019-03-10 20-48-25.png (179.34 KiB) Viewed 907 times
closingWing.FCStd
(218.22 KiB) Downloaded 24 times
hammax
Postby hammax » Mon Mar 11, 2019 6:26 am
… for the first approach a loft could be helpful.
Tilting the tip sketch by placement would improve the profile.
closingWing_4.FCStd
(49.84 KiB) Downloaded 32 times
closingWing_2.FCStd
FC.18.16065
(220.81 KiB) Downloaded 28 times
LeeF
Postby LeeF » Mon Mar 11, 2019 4:51 pm
Hey there - newbie here.
Was trying to use CurvesWB to map sketch to a cylinder, and then offset the mapped sketch, but I keep running into this error:
BRepOffsetAPI_MakeOffsetShape not done
Can any experts here shed any light why this wont work? I've attached the test file if anyone cares to take a look
Thanks !!
test.FCStd
(9.17 KiB) Downloaded 18 times
m.cavallerin
Postby m.cavallerin » Mon Mar 11, 2019 5:22 pm
I saw you updated the thread with a new version of the file; I think that new one is better than other, even for the quality of the surfaces.
Thank you very much.
Cheers.
Michele
GlouGlou
Postby GlouGlou » Fri Mar 22, 2019 11:02 am
I've seen several times PipeShell doesn't match perfectly with a standard Sweep (same parameters). :roll:
This is an example.
PipeshellNoMatch.FCStd
(515.33 KiB) Downloaded 17 times
Chris_G
Postby Chris_G » Fri Mar 22, 2019 3:41 pm
In this case, I think Pipeshell precisely matches the sweep.
In the picture below, you can see that the edge of the orange PipeShell follows the pink curves that are isocurves of the sweep.
I think the difference you are pointing in your screenshot comes from the sweep path that has a slight torsion compared to the cylinder surface.
Look at the comb plot of the attached file.
PipeshellNoMatch-2.FCStd
(575.31 KiB) Downloaded 15 times
GlouGlou
Postby GlouGlou » Sat Mar 23, 2019 2:35 pm
Curves WB is better as the part WB. While the classic Sweep fails, Pipeshell succeed.
thumbs up! ;)
PipeShellNice.FCStd
(61.19 KiB) Downloaded 25 times
freecad-heini-1
Postby freecad-heini-1 » Sun Mar 24, 2019 1:10 pm
There is simplified way to reach the same result with less features.
1. create a sketch in the first direction and extrude it to a face in the part workbench.
2. create a sketch in the second direction and extrude it to a face in the part workbench.
3. select the two faces and create a section out of it in the part workbench.
4. In the curves workbench convert the section curve into a joincurve corner break false.
5. Sketch the profile to sweep and convert it into a curves workbench profile.
6. Create a pipeshell out of the joincurve and profile
freecad-heini-1
Postby freecad-heini-1 » Sun Mar 31, 2019 8:39 pm
Chris_G wrote:Ping
Hi Chris,
in the German forum section I asked if Freecad has something similar to a Creo tool to add a face to a solid with a single command or to replace a flat face with a freeform face.
For example I created this part. The base part is a cuboid. With the Surface-Workbench I created a convex surface.
Here you can find the German topic and my Freecad-file to experiment with.
https://forum.freecadweb.org/viewtopic. ... 12#p298212
https://forum.freecadweb.org/download/file.php?id=80312
Maybe you have a great idea to program a clever replace face tool or add face to solid with one click.
Best regards
Wilfried
