Curves workbench
freecad-heini-1
Re: Curves workbench
Postby freecad-heini-1 » Mon Sep 23, 2019 3:37 pm
hammax wrote:
Mon Sep 23, 2019 10:31 am
… please have a look at your frames' curvature combs and the resulting "cellulitis".
Compared to a Sketcher BSpline with ONLY 4 control points.
Why don't men have cellulite?
Because it looks terrible ... :lol:
GlouGlou
Postby GlouGlou » Mon Sep 23, 2019 6:54 pm
You're right. I wanted stick closely to the picture. That's can't give a baby skin yet.
hammax
Postby hammax » Wed Sep 25, 2019 8:12 am
… just another benefit of CurvesWB:
A solution for a 3D-bow-frame with combined_projection_curves, which is accepted by the Loft tool.
The comb_proj_curve is built by a sideview and (a top view) or better by a front view.
The front view must have a placement "outside" of the bow frame
and must have external references to the endpoints of the side view.
Justcurves_5.FCStd
(157.78 KiB) Downloaded 32 times
Justcurves_4.FCStd
(116.79 KiB) Downloaded 29 times
LLuoss
Postby LLuoss » Thu Sep 26, 2019 1:34 am
LLuoss wrote:
Fri Sep 20, 2019 2:40 am
Chris_G wrote:
Mon Sep 16, 2019 9:11 am
LLuoss wrote:
Mon Sep 16, 2019 8:54 am
Hi,glad to see u again!I'm confused how to do these three steps with python code?Do you have any simple code examples for these three steps?Looking forward to your reply!Thanks!
Don't use this, it is outdated.
Use the Gordon surface.
I already answered about the Gordon surface scripting :
import gordon
gordon = gordon.InterpolateCurveNetwork([bs0,bs1,bs2], [bs3,bs4,bs5], tol=0.1) # the bs* are BSpline curves
my_surface = gordon.surface()
Thanks!Finally it worked.But I still have some questions.Why does the contour of the resulting surface end up not coincident with the BSpline I used?
If I want to use an outline of my surface, how do I extract it?
Does anybody know these problems?It's very important to me!Thanks.
Chris_G
Postby Chris_G » Thu Sep 26, 2019 5:06 am
Something didn't work as good as expected ... that's all I can guess from a screenshot.
LLuoss
Postby LLuoss » Fri Sep 27, 2019 7:24 am
Did you have any problems using Gordon surface before?I still can't solve my problems.
Chris_G
Postby Chris_G » Fri Sep 27, 2019 7:50 am
Of course, I did.
Gordon surface tool can fail or produce wrong results in MANY situations.
So I can't help without a test file.
LLuoss
Postby LLuoss » Sun Sep 29, 2019 6:53 am
Of course, I did.
Ok,thanks!I will send you a test file separately. If you are free, please help to find out what the problem is.
Chris_G
Postby Chris_G » Sun Sep 29, 2019 10:13 am
I have pushed a small change to Gordon surface.
It is now possible to change the max number of control points (it was fixed to 80 before)
In your case, increasing this value to 300 / 400 will help catching the small detail on one side of the surface.
In python script :
gordon1 = gordon.InterpolateCurveNetwork(...)
gordon1.max_ctrl_pts = 400
But it will produce a much heavier surface.
GlouGlou
Postby GlouGlou » Sun Sep 29, 2019 11:20 am
I can't blend two curves. Where my mistake? :roll:
Help. I would like as the red one. Scale1 seems to do nothing.
NotBlend.FCStd
(5.78 KiB) Downloaded 13 times
