Curves workbench
Chris_G
Re: Curves workbench
Postby Chris_G » Sun Sep 29, 2019 12:26 pm
The first edge "JoinCurve013005001" is not good.
It is mathematically valid, but it is wrong for BlendCurve algorithm.
It is a BSpline Curve of degree 3.
It has 4 control points P.
But P1=P2 and P3=P4
On the other hand, you can see that the other curve is good, all control points are distinct:
So the blendcurve fails, because it doesn't support this kind of degenerated curves.
GlouGlou
Postby GlouGlou » Sun Sep 29, 2019 1:35 pm
ok, thanks, so I discretized it. Then it's working.
GlouGlou
Postby GlouGlou » Sun Sep 29, 2019 5:27 pm
I'm trying to split a curve to 3 parts, but its not working. :roll:
I've downloaded the wb today.
Split3Part.FCStd
(4.84 KiB) Downloaded 20 times
GlouGlou
Postby GlouGlou » Sun Sep 29, 2019 5:41 pm
Surface challenge for everyone: make a nice and smooth surface. :D
SurfaceChallenge.FCStd
(8.07 KiB) Downloaded 21 times
Chris_G
Postby Chris_G » Sun Sep 29, 2019 5:54 pm
You have the same value (30%) twice.
I need to add a check for this situation.
By the way, double click the splitCurve (in tree view) for graphical editing.
"v" key to change unit during dragging
GlouGlou
Postby GlouGlou » Sun Sep 29, 2019 6:05 pm
wow you right i must enter 33% and 66% for make a 3 split curves. sorry :? :? :?
Chris_G
Postby Chris_G » Sun Sep 29, 2019 6:16 pm
Numbers without unit are real parameters (not sure it is really useful)
Or you can use % and mm
Negative values are allowed, and are calculated from the end of the curve.
GlouGlou
Postby GlouGlou » Mon Sep 30, 2019 7:48 pm
hammax wrote:
Sun Sep 22, 2019 6:32 am
… keep it simply simple = KISS.
If think too. ;) But i'm trying to most closely with the original drawing.
Why not a tool to iron the surfaces? :lol:
HalfHull.FCStd
(642.93 KiB) Downloaded 19 times
GlouGlou
Postby GlouGlou » Mon Oct 07, 2019 5:55 pm
Strange behaviour: split curve and extend curve move their Z and Y position with this sketch. :?
bizarre.FCStd
(4.18 KiB) Downloaded 14 times
LLuoss
Postby LLuoss » Tue Oct 08, 2019 1:49 am
Chris_G wrote:
Sun Sep 29, 2019 10:13 am
I have pushed a small change to Gordon surface.
It is now possible to change the max number of control points (it was fixed to 80 before)
In your case, increasing this value to 300 / 400 will help catching the small detail on one side of the surface.
In python script :
gordon1 = gordon.InterpolateCurveNetwork(...)
gordon1.max_ctrl_pts = 400
But it will produce a much heavier surface.
I've tried, but my problem still doesn't seem to be solved. I'm using version 0.18
