Curves workbench
GlouGlou
Re: Curves workbench
Postby GlouGlou » Tue Nov 19, 2019 9:21 pm
Trimmed Face doesn't work here. (the joinCurve was forced close)
And Z picked point still at 0.
trimissue.FCStd
(10.34 KiB) Downloaded 7 times
HardRock
Postby HardRock » Wed Nov 20, 2019 5:11 pm
How to create wing surface from root / tip profiles and top/front projections (views)?
wing_test.FCStd
(28.96 KiB) Downloaded 15 times
GlouGlou
Postby GlouGlou » Wed Nov 20, 2019 5:57 pm
Your base curves are usable with CurvedArray of CurvesShape WB.
Have a look there. ;)
https://forum.freecadweb.org/viewtopic.php?f=8&t=36989
HardRock
Postby HardRock » Wed Nov 20, 2019 8:20 pm
Yes, I know that :)
I want to study Curves workbench because it seems to be more flexible.
CurvedShapes WB has some limitations and simplification - for example, you are not able to make wing with different profiles on root and tip, as it usually done on real wings.
I feel that this Curves WB can.
freecad-heini-1
Postby freecad-heini-1 » Fri Nov 29, 2019 8:08 am
Chris_G wrote:Ping
Hi Chris,
I miss the line tool, which creates a line between two points. In the current Curves Workbench it is unfortunately no longer included.
Many greetings
Wilfried
Chris_G
Postby Chris_G » Fri Nov 29, 2019 8:46 am
I just restored it.
But I wonder why you would need it ?
The "editable interpolation curve" and the "blend curve" should both be able to create a straight segment (even though they will be degree 1 BSpline curves instead of real line segment).
freecad-heini-1
Postby freecad-heini-1 » Fri Nov 29, 2019 9:43 am
I just restored it.
Thank you Chris. That is new to me. The editable interpolation curve work, blend curve not:
Chris_G
Postby Chris_G » Fri Nov 29, 2019 10:54 am
Of course, the blend curve still needs 2 edges as input (not vertexes), but you can then set the parameters to the end of the input edges, and set the continuities to C0.
Also, please not that the editable interpolation curve is in edit mode when you create it. You can double-click it in the tree-view to finish editing.
UR_
Postby UR_ » Thu Dec 12, 2019 8:37 am
Hi Chris_G,
I had some problems using GeomInfo on my 4K monitor :roll:
Screenshot 005.png (45.8 KiB) Viewed 161 times
Used font is too tiny and really hard to read. :o
Would you be so kind and change GeomInfo.py line 361
self.myFont.size.setValue(14.0)
to:
self.myFont.size.setValue(FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Curves").GetInt('FontSize', 14))
This will offer an easy way to prevent eye diseases ;)
What do you think about this?
GeomInfo.py.diff.zip
(446 Bytes) Downloaded 3 times
Chris_G
Postby Chris_G » Thu Dec 12, 2019 3:23 pm
Done. Thanks.
I called the parameter : GeomInfoFontSize
