Curves workbench
hammax
Re: Curves workbench
Postby hammax » Fri Jan 10, 2020 2:58 pm
… abused your frame sketch picture,
built a new frame by a 7-control-point Sketcher BSpline
Scaled 2 clones and made a Loft.
If the frames are "smooth" the hull also will be.
Gord_Loft.FCStd
(30.31 KiB) Downloaded 10 times
hammax
Postby hammax » Sat Jan 11, 2020 8:40 am
… and here a possible workflow.
Different frame sketches.
Also with a final Gordon surface.
Gord_Loft_3.FCStd
(12 KiB) Downloaded 7 times
Gord_Loft_2.FCStd
(63.13 KiB) Downloaded 6 times
Will_C
Postby Will_C » Sat Jan 11, 2020 10:08 am
Thank you Hammax.
I will try this approach then :)
GlouGlou
Postby GlouGlou » Fri Jan 24, 2020 6:30 pm
A idea:
Why not use isocurve to make points instead a mesh. (should be an option)
With theses points, we will able to rebuild a new surface (smoothed?) and mix several cloud points to create a new mixed surface with the approximate feature.
and thank you for the new feature Line. ;)
soaring
Postby soaring » Sun Jan 26, 2020 3:56 pm
@Will_C, dont hesitate to share your progress about fuselage to the thread of best practice, i guess it can help other too :) "Best practice: fuselage + wing" : https://forum.freecadweb.org/viewtopic. ... 14#p363614
@hammax thank you for your file "Gord_Loft_2" very helpful ! Dummie question, but in this file, do you know a possibility to get a solid from the Gordon or Gordon_mirr objects ?
@Chris_G : fantastic job, lot of gratitude !
freecad-heini-1
Postby freecad-heini-1 » Mon Jan 27, 2020 9:10 pm
Chris_G wrote:Ping
Hi Chris,
Please look at Blend Curve. The end of the curve is not at the edge, but offset on the surface. This looks like a mistake.
sweep_zwei_bleche_90-grad.FCStd
(15.65 KiB) Downloaded 8 times
Maybe you can look for this feature request at this time:
Chris_G wrote:
Thu Jan 09, 2020 1:48 pm
Hi Wilfried,
I looked at the video.
I see what you ask for.
This should be possible pretty easily.
I lack free time, but I'll give a try when possible.
Best regards
Wilfried
OS: Ubuntu 18.04.3 LTS (XFCE/xubuntu)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
27.01.2020
Chris_G
Postby Chris_G » Tue Jan 28, 2020 5:28 pm
This should be fixed now.
Chris_G
Postby Chris_G » Tue Jan 28, 2020 5:33 pm
I added a new tool : Multi-Loft
The goal is to loft "multi-face" objects like shapestrings.
freecad-heini-1
Postby freecad-heini-1 » Tue Jan 28, 2020 5:42 pm
Thank you very much Chris, and whow, a new Feature to play with. 8-)
What about my feature request / wish for to improve the blend curve?:
https://peertube.mastodon.host/videos/w ... 9f8a5510d0
Postby chrisb » Tue Jan 28, 2020 6:30 pm
I have more and more the feeling that this workbench should be part of core FreeCAD!
