Curves workbench
fc_tofu
Re: Curves workbench
Postby fc_tofu » Fri Apr 24, 2020 6:07 pm
microelly2 wrote:
Fri Apr 24, 2020 11:18 am
The better way to create such volumes (tubes) is to see them as variant of a torus.
Could you please figure out G1 connection at Gordon rim? I made a test with perpendicular profile way, but failed to get G1 connection at mirror rim.
https://forum.freecadweb.org/viewtopic. ... &start=270
microelly2
Postby microelly2 » Sat Apr 25, 2020 4:26 am
The mathematics of a gordon surface does not allow to create such a tangent constraint with these profiles.
You need other profiles.
If you want such a helmet the simplest way is to use another model to create the surface.
here an example how I create tangent helmets
I use a bottom border sketch and some sketches to create the dome.
To get the tangent I insert a lifted bottom.
import numpy as np
hh=3
poles=np.zeros((5,5,3))
ptsa=np.round(np.array([v.Point for v in App.ActiveDocument.Sketch.Shape.Wires[0].Vertexes]),1)
poles=poles.swapaxes(0,1)
poles[0,0:-1]=ptsa[12:17][::-1]
poles[4]=ptsa[4:9]
poles[0]=ptsa[0:5]
poles[4]=ptsa[8:13][::-1]
ptsa=np.array([v.Point for v in App.ActiveDocument.Sketch001.Shape.Wires[0].Vertexes])
poles[1,1:4]=ptsa
ptsa=np.array([v.Point for v in App.ActiveDocument.Sketch002.Shape.Wires[0].Vertexes])
poles[2,1:4]=ptsa
ptsa=np.array([v.Point for v in App.ActiveDocument.Sketch003.Shape.Wires[0].Vertexes])
poles[3,1:4]=ptsa
ud=3
vd=3
mu=[4,1,4]
mv=[4,1,4]
uk=range(len(mu))
vk=range(len(mv))
sf=Part.BSplineSurface()
sf.buildFromPolesMultsKnots(poles,mu,mv,uk,vk,False,False,ud,vd)
a=FreeCAD.ActiveDocument.getObject("ShapeA")
if a is None:
	a=FreeCAD.ActiveDocument.addObject("Part::Feature","ShapeA")
a.Shape=sf.toShape()
polesb=np.zeros((7,7,3))
print (polesb.shape)
polesb[1:-1,1:-1]=poles
polesb[0]=polesb[1]
polesb[-1]=polesb[-2]
polesb=polesb.swapaxes(0,1)
polesb[0]=polesb[1]
polesb[1,1:-1,2] += hh
polesb[-2,1:-1,2] += hh
polesb[2:-2,1,2] += hh
polesb[2:-2,-2,2] += hh
polesb[0,0]=polesb[0,1]
polesb[-1,-1]=polesb[-1,-2]
polesb[0,-1]=polesb[0,-2]
polesb[-1,0]=polesb[-1,1]
ud=3
vd=3
mu=[4,1,1,1,4]
mv=[4,1,1,1,4]
uk=range(len(mu))
vk=range(len(mv))
sf.buildFromPolesMultsKnots(polesb,mu,mv,uk,vk,False,False,ud,vd)
a=FreeCAD.ActiveDocument.getObject("ShapeB")
if a is None:
	a=FreeCAD.ActiveDocument.addObject("Part::Feature","ShapeB")
helmet3.FCStd
(20.12 KiB) Downloaded 9 times
fc_tofu
Postby fc_tofu » Sat Apr 25, 2020 12:28 pm
Quite thank you. I need some time to digest your sample file.
fc_tofu
Postby fc_tofu » Sun Apr 26, 2020 4:23 pm
Chris_G wrote:
Wed Nov 07, 2018 9:00 pm
Sweep2Rails doesn't work on Wire Profiles, but only on profiles made of a single edge.
So you need to join each wire first.
Hello, Chris_G,
I'm curious about the usage of "HQ rule surface".
I modified your sample file, replace rule surface with HQ rule surface as rail object.
But Sweep2Rail command fail to generate point matrix object.
So, what's wrong in my operation, please?
OS: Windows 10 (10.0)
Version: 0.19.20514 (Git)
Hash: a05ffd499366ab12fa1b43f37db73f4f1e9c332d
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Chinese/China (zh_CN)
HQ_rule_sw2r_test.FCStd
(21.06 KiB) Downloaded 11 times
Chris_G
Postby Chris_G » Sun Apr 26, 2020 5:38 pm
I made this tool for very specific cases where the parametrization of the 2 curves were not matching correctly.
This was just an experiment (The whole workbench should be considered experimental, by the way).
So, you'd better not use it.
For PipeShell, the profiles need to be "PipeShell Profiles" (the icon on the left of the Pipeshell one).
See example file attached.
pipeshell-example.FCStd
(91.65 KiB) Downloaded 9 times
hammax
Postby hammax » Mon Apr 27, 2020 10:16 am
… why not Gordon-Surface?
HQ stands rather for "straight profiles", like "Ruled_Surface" in PartWB.
HQ_rule_sw2r_test_2.FCStd
(33.61 KiB) Downloaded 13 times
fc_tofu
Postby fc_tofu » Mon Apr 27, 2020 1:25 pm
I made a revision to your "info.svg" icon.
The original "info.svg" icon is beautiful. But its light color border made it looks smaller than neighbouring icons.
I remove its border and enlarged it. Now, I looks almost the same size as neighbouring icons.
I also removed its shadow like decoration beside "i" letter, in order to get a sharper looking in small size disaply (16px).
Hope your suggestions.
1. Original "info.svg"
2. Revised "info.svg"
Attachment is my revised version.
info.svg
(2.98 KiB) Downloaded 5 times
fc_tofu
Thank you, just for curiosity.
fc_tofu
Postby fc_tofu » Mon Apr 27, 2020 2:09 pm
Thank you, I got what you mean.
Another question. Could you please add "Reverse Normal" option for surface making commands in CurvesWB, such as, Aproximate Loft, PipeShell, Sweep2Rail, Gordon Surface.
It is defficult to decide generated surface normal in CurveWB (and also other workbenches in FreeCAD). So, there often need lot of "PartWB >Reverse Shape" operations before final step (Union), which make history tree quite a mess.
In FreeCAD 0.18, where "Lighting = Two Sides" is default pref, this looks not obvious in viewport. But in FreeCAD 0.19pre, where "Lighting = One Side" is default pref, you will quite know what I means. Also, in FreeCAD 0.19pre, "Reverse Shapes" command is more tiresome, for it can not handle moved objects easily.
https://forum.freecadweb.org/viewtopic. ... 78#p384478
Zolko
Postby Zolko » Mon Apr 27, 2020 6:21 pm
Hello Chris,
I've made a very specific tool that I really needed and couldn't find in the Curves workbench: it allows to offset 3D curves that are planar, in their own plane. The very specific use-case is to make ribs in aircraft wings. The resulting curve can be either a 3D wire (Part.line) or a sketch. It is not perfect, it's quite brute-force, but should be good enough for many people. It can't handle curves, only poly-lines.
I attach the macro, if you think it could be useful to provide it (or an improved version of it) with the Curves workbench, please feel free to do it. I have absolutely no pretence about this little script. I also attach an icon for convenience.
These are the things that make FreeCAD really enjoyable. All comments are welcome.
offset3DCurve.svg
(3.26 KiB) Downloaded 6 times
offset3DCurve.FCMacro
(15.35 KiB) Downloaded 12 times
