Curves workbench
Chris_G
Re: Curves workbench
Postby Chris_G » Tue Jul 14, 2020 11:48 am
Thanks Glouglou.
Pipeshell should be fixed now.
vocx
Postby vocx » Tue Jul 14, 2020 8:12 pm
Chris_G wrote:
Tue Jul 14, 2020 10:26 am
Arc by 3 points : why not
Arc by 2 points + radius : this already exist in 2D (sketcher and maybe Draft), and it is not enough to define a single curve in 3D.[quote=GlouGlou ...
Both of these exist in Draft, Draft_Arc, and Draft_Arc_3Points.
GlouGlou
Postby GlouGlou » Wed Jul 15, 2020 5:59 pm
draft WB features doesn't be linked with parent shape. :(
GlouGlou
Postby GlouGlou » Thu Jul 30, 2020 8:17 pm
Suggested improvement:
SplitCurve on an unique a point with a mm dimension, that's could be parametrize able.
hammax
Postby hammax » Fri Jul 31, 2020 3:58 pm
... or grant a display on DataTab, where the the original length of the curve (to be splitted) is given.
Then one can calculate it "exactly" in %.
Chris_G
Postby Chris_G » Fri Jul 31, 2020 5:13 pm
It is already possible to enter mm values, from curve start (positive values) or from the curve end (negative values) :
hammax
Postby hammax » Sat Aug 01, 2020 3:52 pm
... got it!
I always was seeking for an alternative way to display a fiber winding pattern on a pressure sphere (aerospace).
Split_Curve and Interpolation_Curve are another solution.
(Interpolation_Curve is not exact, compared to great circle construction with Blend_Curve)
FiberWindingSphere_3.FCStd
(34.05 KiB) Downloaded 8 times
FiberWindingSphere.FCStd
FC.18.4
(28.96 KiB) Downloaded 12 times
Chris_G
Postby Chris_G » Mon Aug 03, 2020 8:14 am
I have added 2 new properties to SplitCurve :
- Distance : is a single-value field that is expression-ready
- Cutting Objects : will cut the curve at its nearest point
hammax
Postby hammax » Mon Aug 03, 2020 4:25 pm
... I found another useful application for Split_Curve.
Up to now I couldn't design a clinker built boat => the planking already Wikings used.
Discretized_Edge only delivers equally spaced frame points.
With Split_Curve it is possible to produce parametric and controllable distances for more than one point.
The produced clinker planking example isn't perfect and needs still more work.
But the idea and the feature rises some hope.
( when using Interpolation_Curve better check "Detect Alignment" to false )
Dinghi_2.FCStd
FC.18.4
(388.83 KiB) Downloaded 17 times
GlouGlou
Postby GlouGlou » Mon Aug 03, 2020 5:47 pm
Very nice Chris!
Curve Wb is becoming perfect!
