nice, i my self thought it was fancythschrader wrote: ↑Sun Jul 09, 2017 7:34 pmI like the earring, very nice!
Dev logs of Rebar Addon for FreeCAD - GSoC project
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
althouth I'm still not sure
OS: Linux Mint 18.2 Sonya
Version: 0.17.11509 (Git)
Build type: None
Hash: fdedf8fb4d36043145e8498244177aae16c806a5
Python version: 2.7.12
OCC version: 7.1.0
Build type: None
OCC version: 7.1.0
+1
I like this changes.
One structure can have several rebars.
and this code for the test. A user can change number top and bottom rebar in the properties's dialog.
Test Simple Beam Rebar
10 July 2017
import FreeCAD
import Arch , Draft
import Stirrup
from FreeCAD import Vector
def makeSimpleBeam():
L = 4000-100-100
b = 200
h = 400
doc = FreeCAD.ActiveDocument
concShape = doc.addObject("Part::Box","Concrete")
concShape.Width = b
concShape.Height = h
concShape.Length = L
concShape.Placement.Base = Vector(100,-b/2,-h)
beam = Arch.makeStructure(concShape)
beam.ViewObject.Transparency = 80
covering = 20
dia = 12
dx = covering+dia/2
y = -b/2
points=[Vector(-100-dx,y,-dx-2*dia-6*dia),
Vector(-100-dx,y,-dx),
Vector(+100 + L +200-dx,y,-dx),
Vector(+100 + L +200-dx,y,-dx-2*dia-6*dia),]
line = Draft.makeWire(points,closed=False,face=False,support=None)
line.ViewObject.Visibility = False
rebar1 = Arch.makeRebar(diameter = 12)
rebar1.Base = line
rebar1.Label = 'TopMain'
rebar1.Host = beam
rebar1.Amount = 2
rebar1.Rounding = 2.000
rebar1.MoveWithHost = True
rebar1.Direction = (0.000,1 , 0.000)
#rebar1.Spacing = b-2*dx
rebar1.OffsetStart =dx ; rebar1.OffsetEnd =dx
rebar1.Role = u"Rebar"
points=[Vector(-100-dx,y,-h +dx+2*dia+6*dia),
Vector(-100-dx,y,-h+dx),
Vector(+100 + L +200-dx,y,-h+dx),
Vector(+100 + L +200-dx,y,-h+dx+2*dia+6*dia),]
line2 = Draft.makeWire(points,closed=False,face=False,support=None)
line2.ViewObject.Visibility = False
rebar2 = Arch.makeRebar(diameter = 12)
rebar2.Base = line2
rebar2.Label = 'BottomMain'
rebar2.Host = beam
rebar2.Amount = 2
rebar2.Rounding = 2.000
rebar2.MoveWithHost = True
rebar2.Direction = (0.000,1 , 0.000)
#rebar2.Spacing = b-2*dx
rebar2.OffsetStart =dx ; rebar1.OffsetEnd =dx
rebar2.Role = u"Rebar"
#Stirrup.makeStirrup()
if __name__=="__main__":
makeSimpleBeam()
FreeCAD.ActiveDocument.recompute()
Msg('Done!!\n\n')
Version: 0.17.11508 (Git)
Hash: 087a1c1056d56e7bef0ce3bc6e367441fa0e3a9f
Python version: 2.7.8
OCC version: 7.1.0
@chakree:
At first: I have no programming-skills, my comments are only from a user point of view.
chakree, Im looking exactly for a possibility to draw rebars partially outside the beam,
like shown in your picture. Is that implemented in the actual FC17 dev-snapshot?
Please have a look at
https://forum.freecadweb.org/viewtopic.php?f=13&t=23349
short translation of my german text:
I want to draw rebars in an circular concrete column. If I draw a circle at the top
of the cylinder (in rebar-mode), I get an error. So I used a polygon and "rounded" it.
To produve the vertical radial-bars, I constructed a prisma as a help for attaching
the vertical rebars.
Greetings thomas
(native german speaker, sorry for my english...)
Greetings thomas
Hello, everyone.
I'm glad to see new fascinating improvements in FreeCAD for structural detailings.
Following are my comments in the article regarding this new addon.
(https://cnirbhay.wordpress.com/2017/07/ ... n-freecad/)
Cheers.
Cheers.
thanks for the info, I posted your info in (german forum)cnirbhay wrote: ↑Mon Jul 10, 2017 11:34 am I'm glad to see new fascinating improvements in FreeCAD for structural detailings.
greetings thomas
It is possible to draw rebars that pop out of the beam without problems. Not sure if that works with Amritpal's tools, but it's always possible to draw a custom sketch the way you want.
Great article Nirbhay!
You're welcome, Thomas.thanks for the info, I posted your info in (german forum)
Thanks, Yorik.Great article Nirbhay!
I try to coding for a circular column.thschrader wrote: ↑Mon Jul 10, 2017 8:28 am @chakkree:
Greetings thomas
But spiral stirrup is not a smooth curve.
Test Circular Column Rebbar
11 July 2017
import FreeCAD
import Arch , Draft
from math import pi , sin , cos
def makeCircularColumn():
dia_col = 300.0*2
h_col = 5000
concShape = doc.addObject("Part::Cylinder","Concrete")
concShape.Radius = dia_col/2
concShape.Height = h_col
column = Arch.makeStructure(concShape)
column.ViewObject.Transparency = 80
L = h_col+500
iAngle = 0.0
covering = 50
dia = 20 # main rebar
dia_stir = 16
dx = covering+dia_stir+dia/2
R = dia_col/2. -dx #dia_col-dx
num = 8
for i in range(0,num):
iAngle = i*(2*pi)/num
x = R* cos(iAngle)
y = R* sin(iAngle)
#Msg("%d x = %.1f , y=%.1f\n"%(i+1 , x,y))
points=[Vector(x,y,0.0),
Vector(x,y,L)]
line = Draft.makeWire(points,closed=False,face=True,support=None)
rebar1 = Arch.makeRebar(diameter = dia)
rebar1.Base = line
rebar1.Label = 'RebarMain%d'%(iAngle+1)
rebar1.Host = column
rebar1.Amount = 1
rebar1.OffsetStart =0 ; rebar1.OffsetEnd =0
spacing = 150
segment = 8*2
#numCircular = h_col / spacing
dx = covering+dia_stir/2
dz = float(spacing) / segment
z = 20
R = dia_col/2. -dx
points = []
#for n in range(0,numCircular):
count = 1
while (z<h_col):
for i in range(0,segment):
#Msg('count = %d , i=%d \n'%(count,i))
iAngle = i*(2*pi)/segment
x = R* cos(iAngle)
y = R* sin(iAngle)
points.append( Vector(x,y,z))
z += dz
count += 1
line2 = Draft.makeWire(points,closed=False,face=True,support=None)
rebar2 = Arch.makeRebar(diameter = dia_stir)
rebar2.Base = line2
rebar2.Label = 'spiralStirrup'
rebar2.Host = column
rebar2.Amount = 1
rebar2.OffsetStart =0 ; rebar1.OffsetEnd =0
Msg('Done!!\n\n')
OCC version: 7.1.0
