for solids that aren't in X, Y or Z direction, that seems it get wrong location for reinforcement:
freecad .18, python 3, pyqt5, manjaro linux, conda build
Dev logs of Rebar Addon for FreeCAD - GSoC project
- ebrahim raeyat
- hardeeprai
list index out of range
I can put straight rebars.
But on putting vertical straight rebars or stirrups, I am getting
error: Out of range.
What solution can be there?
See below signature.
Issue is same on FreCAD.17 on Linux, but it works fine on .18 (not testing on .17, but expected that it will work) on MSWindows.
My system is:
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15215 (Git)
Hash: 54799368944d408a09fcdde41f89f20d282a9b8a
Python version: 2.7.12
H.S.Rai
.Org.Com
http://hsrai.wordpress.com/
File "/home/hsrai/.FreeCAD/Mod/Reinforcement/Stirrup.py", line 151, in clicked
self.accept(button)
File "/home/hsrai/.FreeCAD/Mod/Reinforcement/Stirrup.py", line 175, in accept
rounding, True, amount, self.SelectedObj, self.FaceName)
File "/home/hsrai/.FreeCAD/Mod/Reinforcement/Stirrup.py", line 220,
in makeStirrup
FacePRM = getParametersOfFace(structure, facename, False)
File "/home/hsrai/.FreeCAD/Mod/Reinforcement/Rebarfunc.py", line
166, in getParametersOfFace
x = face_center_pt[0]
<type 'exceptions.IndexError'>: list index out of range
self.accept(button)
in makeStirrup
in makeStirrup
File "/home/hsrai/.FreeCAD/Mod/Reinforcement/StraightRebar.py", line
134, in clicked
self.accept(button)
154, in accept
rebar = makeStraightRebar(f_cover, (coverAlong, cover), rt_cover,
lb_cover, diameter, True, amount, orientation, self.SelectedObj,
self.FaceName)
208, in makeStraightRebar
FacePRM = getParametersOfFace(structure, facename)
167, in getParametersOfFace
y = face_center_pt[1]
154, in accept
self.FaceName)
My system is:
H.S.Rai
.Org.Com
self.accept(button)
in makeStirrup
self.accept(button)
in makeStirrup
in makeStirrup
134, in clicked
self.accept(button)
154, in accept
self.FaceName)
154, in accept
self.FaceName)
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
Yeah! I am working on this issue. I will give updates soon.ebrahim raeyat wrote: ↑Mon Oct 08, 2018 7:21 pm Thank you amrit for your great work. I am very interesting to it. is there any effort to port reinforcement to python3 and pyqt5?
very thanks.
Thanks,
At initial, this addon was mainly created for vertical and horizontal structural element (as this type of structure are in most of the cases). But you are right. Rebars can hold its position in any structure either it is horizontal, vertical or inclined at some angle. However, this problem can be solved if we constraint the sketch with structure face but because of a topological naming problem we cannot choose this path. So, we have to think something better.ebrahim raeyat wrote: ↑Mon Oct 08, 2018 9:21 pm for solids that aren't in X, Y or Z direction, that seems it get wrong location for reinforcement:
- ebrahim raeyat
@amrit it works with command line and therefore it didn't have any problem with python3, but some minor change need for pyqt5 to work and show panel.
Thanks.
Congratulations guys!, now rebar addon supports QT5 and Python3. You may try this.ebrahim raeyat wrote: ↑Sat Nov 17, 2018 5:59 pm @amrit it works with command line and therefore it didn't have any problem with python3, but some minor change need for pyqt5 to work and show panel.
Thanks.
Thanks,
Re: list index out of range
I have fixed this issue. Commit: https://github.com/amrit3701/FreeCAD-Re ... 829dd649bbhardeeprai wrote: ↑Sat Nov 17, 2018 3:07 pm I can put straight rebars.
Thanks,
- ebrahim raeyat
Very thanks. It works perfectly. thanks you so much
