you could try to export the one from your dwg to dxf, import it to FC and make a face out of it (maybe a bit transparent). such flat people are actually quite common in 3dthschrader wrote: ↑Sun Jul 09, 2017 5:18 pm I forgot:
See autocad-drawing, the man standing beneath the mast.
Where can I find a model of a man for loading in FC?
thomas
Dev logs of Rebar Addon for FreeCAD - GSoC project
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
Today is your lucky day, I had made this file with human profile silhouettes a small while ago so I can use these whenever needed.thschrader wrote: ↑Sun Jul 09, 2017 5:18 pm I forgot:
thomas
Here is the link for the github download
https://github.com/chopinregis/Freecad- ... LATE.fcstd
I will think about your other question.
- human profile silhouette in freecad
- Screenshot from 2017-07-09 14-41-42.png (133.56 KiB) Viewed 1895 times
then you can try to open the pdf in inkscape and save the person as svg or dxf, then import it to FC, they cannot stop us or just get the ones from regis... i also just made one quicklythschrader wrote: ↑Sun Jul 09, 2017 6:42 pmthe autocad-pic is taken from an pdf-file. I never get dwg from the cad-technicians,
because they know that I have no autocad.
regis, thanks for the file.
Im looking for a nice 3d-model.
...and saso: I havent inkscape too...
- worker.png (160.19 KiB) Viewed 1881 times
well, personally I prefer such things to be simple, more details more problems, but here is one quick example...
https://grabcad.com/library/worker-man- ... art-file-1
saso, thanks for the link, looking good. I will have a look at it.saso wrote: ↑Sun Jul 09, 2017 7:33 pm ... but here is one quick example...
greetings thomas
That's a good workflow but it would be better if the scale tool in freecad was a bit better because the problem is how do you get your 2d scaled, but when you do import exports between files you loose the scale. Unless you've got another small trick up your sleeves i'll like to hear about it.saso wrote: ↑Sun Jul 09, 2017 6:57 pmthen you can try to open the pdf in inkscape and save the person as svg or dxf, then import it to FC, they cannot stop us or just get the ones from regis... i also just made one quicklythschrader wrote: ↑Sun Jul 09, 2017 6:42 pmthe autocad-pic is taken from an pdf-file. I never get dwg from the cad-technicians,
person.FCStd
a nice 3d model of the worker in picture?thschrader wrote: ↑Sun Jul 09, 2017 7:15 pm regis, thanks for the file.
take a look at that, i've never played with it but i'm sure you can find something interesting to work with
http://www.makehuman.org/
