Dev logs of Rebar Addon for FreeCAD - GSoC project
- Pauvres_honteux
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
@amrit3701, this is probably a silly question, but are there no use cases where one would like to have tetrahedron rebars?
Background: when we mech' guys want something ultra stiff we try to create a space frame (3D) truss. E.G. a lifting crane.
https://en.wikipedia.org/wiki/Truss
https://en.wikipedia.org/wiki/Crane_(machine)
chakkree one of these days you should think of making an addon of tools like this, we could integrate that to the Arch WB too!
yorik wrote:
I have also created Bent shape rebar. Please suggest if any improvement is needed.chakkree wrote:
Regards,
Hi Amritpal, nice tool!
Anchor lenghts parameter in bent shape rebar does not react. After creating the bent shape, doubleclick on
bentshape, then I wanted to change anchorlenghts from 50 to 250 mm. after pressing ok no reaction,
the value switches back to 50 mm.
regards thomas OS: Windows 10
Version: 0.17.11654 (Git)
Hash: 81bdb1f276540427872c72d2033c3f400a89a626
Python version: 2.7.8
OCC version: 7.1.0
From a mechanical point of view a concrete-beam with rebars reacts like a framework.Pauvres_honteux wrote: ↑Thu Jul 27, 2017 9:35 am Background: when we mech' guys want something ultra stiff we try to create a space frame (3D) truss. E.G. a lifting crane.
Broken lines are the compression zones ==> no rebars needed.
regards thomas
Could we have an apply button, so one could change the rebar without closing the task window every time?
There have many things to learn for making an addon.
1. Pyside , QTWidget ,etc (programming techniques)
2. Git System (process for FreeCAD developer). It's new for me, like Thomas my first coding is Forthan77
3. My English
(are there still existing compilers for F77?)
Amazed!. Anchor length work on mine side. See the below screenshot.thschrader wrote: ↑Thu Jul 27, 2017 9:34 pm Hi Amritpal, nice tool!
Can you paste the output of a report view (View -> Panels -> Report View)?
