Amazing. By the way great freecad ninja party.amrit3701 wrote: ↑Wed Aug 09, 2017 3:51 pmYeah! I have completed my 3rd task. Now, all rebar dialog boxes have "Apply" button.amrit3701 wrote: ↑Sat Aug 05, 2017 7:10 pm Hello everyone,
Here is my TODO task list which I will complete before final phase evaluation:
1. Complete circular stirrup (spiral) which Yorik posted it in his previous post in this thread.
2. Create wiki pages for all rebar shapes which I completed.
3. Add "Apply" button in all dialog boxes of rebar shapes.
4. Add user facility to give custom spacing when he/she creating rebar. Now user gives custom spacing after creating rebar with rebar tool.
5. Also, discuss with Yorik that can we add rebar tools as default FreeCAD feature.
Thanks,
Dev logs of Rebar Addon for FreeCAD - GSoC project
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
Well anyway, it seems that this is actually done automatically based on the operating system someone uses It is looking as expected here.
Here is one bug, probably for yorik, if using StraightRebar the vertical orientation will create wrong Centerline representation of the rebar, both if choosing it as a first option or if switching later from horizontal to vertical.
Version: 0.17.11749 (Git)
Hash: 6c4bdf24dfd697ee212ec5950969125851a0907c
Python version: 2.7.8
OCC version: 7.1.0
Locale: Slovenian/Slovenia (sl_SI)
OCC version: 7.1.0
I use to wonder why you have the 'cancel, apply, ok' trio combination in applications when validating and modifying inputs,
over the years i've convinced my self that cancel is needed by default, apply is perhaps when you are modifying some data, and it doesn't have have an auto generate preview, or realtime input modification preview of some sort, then you hit apply, it changes, then you say, i like it, hmm i don't like, change again, apply, etc, and then when you are staisfied you hit "ok", to validate the final option and to close out of the submenu.
But the strange thing in freecad is that you have the reload botton, and you have some part tools which when you hit apply the generate something like okay as well, so no difference, an then you have in the arch workbench, the section cut tool which when you modify something, not only does it not generate automatically, (maybe for the better because crazy complex calc which crash program at this point might make freecad unsable in the end, so it is best to have an option that tells the section plane, ok recompute new changes.
Yes, it depends on operating system. I using Linux (Ubuntu) and it sorted buttons as per dictionary order (like according to the first alphabet). May be we can set the order of standard buttons but at present, I don't know how.
Regards,
@amritpal/chakree:
please see
https://forum.freecadweb.org/viewtopic. ... 52#p186052
EDIT 10.08.17
Circular stirrup tool:
This happens when you use default parameters...
please see
EDIT 10.08.17
