Dev logs of Rebar Addon for FreeCAD - GSoC project
chakkree
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
Postby chakkree » Thu Jul 13, 2017 6:19 am
Test create double stirrups, using basic ArchRebar Object.
Stirrup used rebar-addon's function to get DWire.
  TestSimpleBeam2.py
   13 Jul 2017
import Arch
from FreeCAD import Vector
from Stirrup import getTrueParametersOfStructure, getParametersOfFace ,getpointsOfStirrup
def makeSimpleBeam2():
    L = 4000.0
    b = 200
    h = 400
    col_width = 200
    Ln = L-2*(col_width/2.)
    concrete = Arch.makeStructure(length=Ln,width=b,height=h)
    concrete.Placement.Base = Vector(L-col_width/2., 0 , -h/2.)
    concrete.ViewObject.Transparency = 80
    FreeCAD.ActiveDocument.recompute()
    covering = 20
    dia = 19  # Main
    diameter = 9 # Stirrup
    dx = covering+dia/2
    y = -b/2
    points=[Vector(-100-dx,y,-dx-2*dia-6*dia),
            Vector(-100-dx,y,-dx-diameter/2.),
            Vector(+100 + Ln +200-dx,y,-dx-diameter/2),
            Vector(+100 + Ln +200-dx,y,-dx-2*dia-6*dia),]
    line = Draft.makeWire(points,closed=False,face=False,support=None)
    line.ViewObject.Visibility = False
    rebar1 = Arch.makeRebar(diameter = 12)
    rebar1.Base = line
    rebar1.Label = 'TopMain'
    rebar1.Host = concrete
    rebar1.Amount = 3
    rebar1.Rounding = 2.000
    rebar1.MoveWithHost = True
    rebar1.Direction = (0.000,1 , 0.000)
    #rebar1.Spacing = b-2*dx
    rebar1.OffsetStart =dx+diameter/2. ; rebar1.OffsetEnd =dx+diameter/2.
    rebar1.Role = u"Rebar"
    points=[Vector(-100-dx,y,-h +dx+2*dia+6*dia),
            Vector(-100-dx,y,-h+dx+diameter/2.),
            Vector(+100 + Ln +200-dx,y,-h+dx+diameter/2.),
            Vector(+100 + Ln +200-dx,y,-h+dx+2*dia+6*dia),]
    line2 = Draft.makeWire(points,closed=False,face=False,support=None)
    line2.ViewObject.Visibility = False
    rebar2 = Arch.makeRebar(diameter = 12)
    rebar2.Base = line2
    rebar2.Label = 'BottomMain'
    rebar2.Host = concrete
    rebar2.Amount = 3
    rebar2.Rounding = 2.000
    rebar2.MoveWithHost = True
    rebar2.Direction = (0.000,1 , 0.000)
    #rebar2.Spacing = b-2*dx
    rebar2.OffsetStart =dx+ diameter/2. ; rebar1.OffsetEnd =dx+ diameter/2.
    rebar2.Role = u"Rebar"
    # Double Stirrup
    b1 = b/2+dia/2+20
    concreteDummy = Arch.makeStructure(length=Ln,width=b1 ,height=h)
    concreteDummy.Placement.Base = Vector(L-col_width/2., +(b-b1)/2 , -h/2.)
    concreteDummy.Label = 'Dummy1'
    concreteDummy.ViewObject.Transparency = 70
    #selected_obj = FreeCADGui.Selection.getSelectionEx()[0]
    structure = concreteDummy
    facename = 'Face6' #selected_obj.SubElementNames[0]
    #facename
    face = structure.Shape.Faces[int(facename[-1]) - 1]
    StructurePRM = getTrueParametersOfStructure(structure)
    FacePRM = getParametersOfFace(structure, face, False)
    FaceNormal = face.normalAt(0,0)
    FaceNormal = face.Placement.Rotation.inverted().multVec(FaceNormal)
    s_cover =  20 #b -(b/2.0-20-dia/2.0)/2.0
    bentAngle = 135
    bentFactor = 6
    rounding=2
    spacing = 175
    num = int(L/spacing)+1
    amount_spacing_value = num
    f_cover = ( L-((num-1)*spacing) )/2.0
    points = getpointsOfStirrup(FacePRM, s_cover, bentAngle, bentFactor, diameter, rounding, FaceNormal)
    line = Draft.makeWire(points, closed = False, face = True, support = None)
    line.Support = [(structure, facename)]
    stir = Arch.makeRebar(structure, line, diameter, amount_spacing_value, f_cover)
    stir.Direction = FaceNormal.negative()
    stir.Rounding = rounding
    stir.Role = u"Rebar"
    stir.Label = 'Stirrups1'
    stir.MoveWithHost = True
    concreteDummy2 = Arch.makeStructure(length=Ln,width=b1 ,height=h)
    concreteDummy2.Placement.Base = Vector(L-col_width/2., -(b-b1)/2 , -h/2.)
    concreteDummy2.Label = 'Dummy2'
    concreteDummy2.ViewObject.Transparency = 70
    structure = concreteDummy2
    #facename
    f_cover = ( L-((num-1)*spacing) )/2.0+diameter*1.5
    stir2 = Arch.makeRebar(structure, line, diameter, amount_spacing_value, f_cover)
    stir2.Direction = FaceNormal.negative()
    stir2.Rounding = rounding
    stir2.Role = u"Rebar"
    stir2.Label = 'Stirrups2'
    stir2.MoveWithHost = True
    #stir2.OffsetEnd =57.
    concreteDummy.ViewObject.Visibility=False
    concreteDummy2.ViewObject.Visibility=False
    stir2.OffsetEnd = 61. # fake
if __name__=="__main__":
    makeSimpleBeam2()
    Msg('Done!!\n\n')
Rebar Addon: Commits on Jul 12, 2017
Version: 0.17.11570 (Git)
Hash: a68940340747d3f18818fc7b0bc72eb59e7a0f25
Python version: 2.7.8
OCC version: 7.1.0
thschrader
Postby thschrader » Thu Jul 13, 2017 7:24 am
amrit3701 wrote:
Fri Jul 07, 2017 1:19 pm
With above PR, Rebar object has the ability to create non-uniform spacing between rebars.
For eg. Suppose we have a column having height 1000 mm and values of offset start and offset end of rebar object is equal to 25 mm. If we given custom spacing 6@50+4@100+6@50 it will create 50 mm spacing between 6 rebars at the start portion, 100 mm spacing between 4 rebars in the middle portion and 50 mm spacing between 6 rebars in the last portion.
For getting the correct result, first user needs to calculate spacing manually and then give that values to custom spacing property of rebar object otherwise it will get a strange result.
Amritpal :D
I got it. Please put blue text into dialog-icon :D
Still playing with "custom-spacing". Give me a try...
regards thomas
amrit3701
Postby amrit3701 » Thu Jul 13, 2017 11:33 am
+1
Great. It will be really helpful for me in the future.
Regards,
amrit3701
Postby amrit3701 » Thu Jul 13, 2017 1:17 pm
yorik wrote:
Wed Jul 12, 2017 3:25 pm
The "custom spacing" button is only available when editing the rebar, not when creating it, is that normal?
According to me, the "custom spacing" button will run outside from the rebar dialog box because now the user will only give a custom spacing with rebar distribution dialog box if he/she created rebar from rebar addon. To overcome this limitation I think we should add "custom spacing" button inside property view of the rebar object.
@Yorik
Give your views on that?
Regards,
regis
Postby regis » Thu Jul 13, 2017 2:27 pm
@Yorik
Regards,
custom spacing inside property view data is not a bad idea. ;)
yorik
Site Admin
Postby yorik » Thu Jul 13, 2017 2:27 pm
This would require to create a new type of property to FreeCAD core, plus an editor for it, etc... Lots of work for something that will be used only once (in rebar) I think.
But this is not what I was asking. The problem was this: When you create a rebar, the "custom spacing" button is disabled (greyed out). Then, if you create the rebar (click OK), then double-click it to edit it, the task dialog appears again, and, this time, the "custom spacing" button is enabled. I wondered why it is disabled the first time.
regis
Postby regis » Thu Jul 13, 2017 6:37 pm
in this tutorial I demonstrate another area where the rebar tool can be used on draftwire lines instead of depending on a face, but for this tutorial I used the pipe tool to achieve the same thing. Any ideas, conversations about if this is a necessary feature for the rebar? you guys understand coding more than me, so I'll leave that open to your imagination.
phpBB [video]
chakkree
Postby chakkree » Fri Jul 14, 2017 5:25 am
Test create a column with double stirrups.
  TestColumn01.py
   14 Jul 2017
import Arch
import Draft
from math import radians,cos
def makeColumn01():
    h = 3000.0
    b = 400
    t = 400
    col_width = 200
    y = 0
    #Ln = L-2*(col_width/2.)
    concrete = Arch.makeStructure(length=t,width=b,height=h)
    concrete.Placement.Base = Vector(0, 0 , 0)
    covering = 20
    dia = 16  # Main
    dx = covering+diameter+dia/2
    R = 2*dia
    LHook = 6*dia + 500
    z = -400
    rebarMain = []
    rebarMain.append({'x':-t/2+dx , 'y':-b/2+dx , 'angle':45} )
    rebarMain.append({'x':+t/2-dx , 'y':-b/2+dx , 'angle':90+45} )
    rebarMain.append({'x':+t/2-dx , 'y':+b/2-dx , 'angle':-90-45} )
    rebarMain.append({'x':-t/2+dx , 'y':+b/2-dx , 'angle':-45} )
    rebarMain.append({'x':-t/2+dx , 'y':0 , 'angle':0} )
    rebarMain.append({'x':0 , 'y':-b/2+dx , 'angle':90} )
    rebarMain.append({'x':+t/2-dx , 'y':0 , 'angle':180} )
    rebarMain.append({'x':0 , 'y':+b/2-dx , 'angle':-90} )
    count = 1
    for iBar in rebarMain:
        x = iBar['x']
        y = iBar['y']
        points=[Vector(x-R-LHook,y,z),
                Vector(x,y,z),
                Vector(x,y,+h+1000),]
        line.Support = [(concrete, 'Face1')]
        Draft.rotate(line,  iBar['angle'] , Vector(x,y,0)  )
        rebar1 = Arch.makeRebar(diameter = dia)
        rebar1.Base = line
        rebar1.Label = 'Main%d'%count
        rebar1.Amount = 1
        rebar1.Rounding = 3.000
        count +=1
    s_cover = 20
    bentAngle = 135
    bentFactor = 6
    rounding=2
    spacing = 250
    num = int(h/spacing)+1
    f_cover = ( h-((num-1)*spacing) )/2.0
    stir1 = Arch.makeRebar(structure, line, diameter, amount_spacing_value, f_cover)
    stir1.Direction = FaceNormal.negative()
    stir1.Rounding = rounding
    stir1.Role = u"Rebar"
    stir1.Label = 'Stirrups1'
    stir1.MoveWithHost = True
    stir1.CustomSpacing = "%d@%d"%(num-1 ,spacing )
    stir1.OffsetStart = 100
    f_cover += diameter
    b1 = ((b/2.0)*cos(radians(45))*2) - covering
    s_cover = (b - b1)/2.0
    Draft.rotate(line,  45 , Vector(0,0,0)  )
    stir2.CustomSpacing = "%d@%d"%(num-1 ,spacing )
    stir2.OffsetStart = 100-diameter
    makeColumn01()
    Msg('Done!!\n\n')
OCC version: 7.1.0
thschrader
Postby thschrader » Fri Jul 14, 2017 8:32 am
in this tutorial I ...
At regis off topic:
I downloaded the spaceframe from your github.
For me as a (german) structural engineer it would be of interest,
which loadings your engineers must use for a location in africa (especially wind loading).
Excellent video. regards thomas
Jee-Bee
Postby Jee-Bee » Fri Jul 14, 2017 8:47 am
