Dev logs of Rebar Addon for FreeCAD - GSoC project
regis
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
Postby regis » Fri Jul 14, 2017 11:19 am
thschrader wrote:
Fri Jul 14, 2017 8:32 am
regis wrote:
Thu Jul 13, 2017 6:37 pm
in this tutorial I ...
At regis off topic:
I downloaded the spaceframe from your github.
For me as a (german) structural engineer it would be of interest,
which loadings your engineers must use for a location in africa (especially wind loading).
Excellent video. regards thomas
Haha that's great, you can make some tangible recommendation. The model I drew is just a basic one, as you can see the connection are not yet realistic. Although not an ingineer, I would like to have your opinion on such types of structure.
A while ago I came about this pdf but it looks 'chinese' to me as i don't undertand how to use the information and not even sure if it relates well.
http://www.saevfors.se/Hurricane/Manual_5.pdf
But mostly it is meant for the Tropical regions of the africa. the dark green mostly
thschrader
Postby thschrader » Fri Jul 14, 2017 11:36 am
At regis off topic:
regis, thanks for the manual.
wind-loading phillipines: 280 km/h ==> in germany NO building would survive... :shock:
about statics: when I have a little bit more time, I can load your spaceframe into my
3d-framework-program. Lets see, how the structure reacts.. :D regards thomas
amrit3701
Postby amrit3701 » Fri Jul 14, 2017 5:18 pm
regis wrote:
Sun Jul 09, 2017 10:17 am
Beautiful, thank you so much, and thank you aswell for improving the rebar tool. you have no idea how significant this is. May I ask, what is your roadmap for this project?
Pardon me for the late reply. :)
Here is a detailed roadmap of rebar addon: https://brlcad.org/wiki/User:Amritpal_s ... c_proposal
Regards,
amrit3701
Postby amrit3701 » Fri Jul 14, 2017 5:23 pm
regis wrote:
Wed Jul 12, 2017 4:05 pm
Yes as you suggested it works on my system when I use the normal structure, but it doesn't work from when the structure is derived from a wire.
@all
Now, I have added support to rebar add-on when structure element is derived from any object (like wire, sketch etc.). Comments are welcome. :)
Regards,
amrit3701
Postby amrit3701 » Fri Jul 14, 2017 5:31 pm
chakkree wrote:
Fri Jul 14, 2017 5:25 am
Test create a column with double stirrups.
+1.
I have updated the getParametersOfFace(structure, facename, sketch = True) function. Now it takes a face name of the structure as an argument instead of face object and it also returns parameters of a face when structure element is derived from any object (like a sketch, wire etc).
https://github.com/amrit3701/FreeCAD-Re ... 45efd2R171
Regards,
regis
Postby regis » Sat Jul 15, 2017 1:09 am
@all
Regards,
this will be a major mile stone, I can't wait to test it out. will get back with some results when i get the chance.
amrit3701
Postby amrit3701 » Sat Jul 15, 2017 7:31 am
I said that I already did this. So, you may test it now. :)
Regards,
thschrader
Postby thschrader » Sat Jul 15, 2017 10:09 am
@all
Regards,
Amritpal,
well done!
Beam is from part-design-WB. I play with the custom-spacing.
regards Thomas
rebartest_15072017.FCStd
(56.82 KiB) Downloaded 9 times
Version: 0.17.11580 (Git)
Hash: aa07c777453258edf9fed304cf82bcfeb8bdea95
Python version: 2.7.8
OCC version: 7.1.0
thschrader
Postby thschrader » Sat Jul 15, 2017 10:55 am
set "amount=1" in dummy ==> create "polar-array".
ring.FCStd
(117.88 KiB) Downloaded 8 times
OCC version: 7.1.0
regis
Postby regis » Sat Jul 15, 2017 11:43 am
Regards,
not quite yet, so process i use is that I draw a draft wire shape like rectangle etc, and the convert that draftwire into a structure
no success yet
"Cannot identified shape or from which base object structural element is derived"
Screenshot from 2017-07-15 07-41-56.png (264.08 KiB) Viewed 494 times
