Dev logs of Rebar Addon for FreeCAD - GSoC project
thschrader
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
Postby thschrader » Sun Jul 23, 2017 2:16 pm
amrit3701 wrote:
Sun Jul 23, 2017 10:54 am
thschrader wrote:
Sun Jul 23, 2017 8:58 am
Yes sir !
Can you share the .fcstd file too?
Regards,
Amritpal, heres the file.
Congredulations to your and chakkrees work from me too :)
rahmen.FCStd
(251.68 KiB) Downloaded 25 times
Version: 0.17.11622 (Git)
Hash: 5ffe17153d84e5b361ba4c41e56c62977619f589
Python version: 2.7.8
OCC version: 7.1.0
chakkree
Postby chakkree » Tue Jul 25, 2017 7:53 am
Test create rebars in footing with 3 types of rebars.
TestFooting01.FCStd
(80.2 KiB) Downloaded 16 times
#-*- coding=utf8 -*-
   TestFooting1.py
import FreeCAD
import Draft
import Arch
from FreeCAD import Vector
from math import cos, radians
# BS8666
def shape21(A=300, B=1000, C=300):
    points=[Vector(0,0,A),
            Vector(0,0,0),
            Vector(B,0,0),
            Vector(B,0,C),
    line = Draft.makeWire(points,closed=False,face=False,support=None)
    return line
def shape41(A=100, B=300, C=1000, D=300, E=100):
    points=[Vector(A,0,B),
            Vector(0,0,B),
            Vector(0,0,0),
            Vector(C,0,0),
            Vector(C,0,D),
            Vector(C-E,0,D),
    return line
def shape47(A=300, B=100, C=2*12+5*12, D=2*12+5*12, R=2*12):
    points=[Vector(2*R,0,A-C),
            Vector(2*R,0,A),
            Vector(0,0,A),
            Vector(0,0,0),
            Vector(B,0,0),
            Vector(B,0,A),
            Vector(B-2*R,0,A),
            Vector(B-2*R,0,A-D),
    return line
def makeFooting1(rebarType=1):
    B = 1000
    L = B
    t = 300
    covering = 50
    dia = 12
    footing1 = Arch.makeStructure(length=L,width=B,height=t,name='Footing1')
    footing1.Placement.Base=Vector(+L/2., 0 , +t/2.)
    footing1.ViewObject.Transparency = 80
    R = 2*dia
    if rebarType==1:
        A1 = t-2*covering-dia/2.
        B1 = L-2*covering-dia
        line1 = shape21(A=A1 , B=B1  , C=A1)
        line1.Support = [footing1,'Face1']
        Draft.move(line1, Vector(-B1/2  ,-B/2,+covering+dia/2.))
    elif rebarType==2:
        A1 = R+6*dia
        B1 = t-2*covering-dia
        C1 = L-2*covering-dia
        line1 = shape41(A=A1, B=B1, C=C1, D=B1, E=A1)
        Draft.move(line1, Vector(-C1/2  ,-B/2,+covering+dia/2.))
    elif rebarType==3:
        line1 = shape47(A=A1, B=B1, C=2*12+5*12, D=2*12+5*12, R=2*12)
    line1.ViewObject.Visibility = False
    rebar1 = Arch.makeRebar(diameter = dia)
    rebar1.Base = line1
    rebar1.Label = 'CustomRebar_bar_No_1'
    rebar1.Host = footing1
    rebar1.Amount = 8
    rebar1.OffsetStart = covering + 2*R
    rebar1.OffsetEnd = covering + 2*R
    rebar1.Direction = (0.0, 1.0, 0.0)
    rebar1.Rounding = 2
    rebar1.ViewObject.ShapeColor = (0.0,0.0,1.0)
    if rebarType==1:
        A2 = t-2*covering-dia/2. - dia
        B2 = B-2*covering-dia
        line2 = shape21(A=A2 , B=B2  , C=A2)
        line2.Support = [footing1,'Face1']
        Draft.rotate(line2,90 ,  Vector(0,0,0) , Vector(0,0,1) )
        Draft.move(line2, Vector(-L/2  ,-B1/2 ,+covering+dia/2.+dia))
    elif rebarType==2:
        A2 = R+6*dia
        B2 = t-2*covering-dia - dia
        C2 = B-2*covering-dia
        line2 = shape41(A=A1, B=B1, C=C1, D=B1, E=A1)
        Draft.move(line2, Vector(-L/2  ,-C2/2,+covering+dia/2.+dia))
    elif rebarType==3:
        line2 = shape47(A=A1, B=B1, C=2*12+5*12, D=2*12+5*12, R=2*12)
        Draft.move(line2, Vector(-L/2  ,-B1/2,+covering+dia/2.+dia))
    line2.ViewObject.Visibility = False
    rebar2 = Arch.makeRebar(diameter = dia)
    rebar2.Base = line2
    rebar2.Label = 'CustomRebar_bar_No_2'
    rebar2.Host = footing1
    rebar2.Amount = 8
    rebar2.OffsetStart = covering + 2*R
    rebar2.OffsetEnd = covering + 2*R
    rebar2.Direction = (1.0, 0.0, 0.0)
    rebar2.Rounding = 2
    rebar2.ViewObject.ShapeColor = (0.0,1.0,0.0)
if __name__=='__main__':
    Msg('Done!!\n\n')
    FreeCAD.ActiveDocument.recompute()
Rebar Addon: Commits on Jul 24, 2017(81 commits)
Version: 0.17.11654 (Git)
Hash: 81bdb1f276540427872c72d2033c3f400a89a626
OCC version: 7.1.0
amrit3701
Postby amrit3701 » Tue Jul 25, 2017 4:07 pm
chakkree wrote:
Thu Jul 20, 2017 3:28 am
I think stirrup should be separate side cover in four parts.(Example in attached picture)
TestColumn02.FCStd
   TestColumn02.py
   20 Jul 2017
import FreeCAD
import Arch
import Draft
# Custom DWire
# *** Prototype ***
class StirrupShape(Draft._Wire):
    def __init__(self,obj):
        Draft._Wire.__init__(self,obj)
        obj.addProperty("App::PropertyLength", "A",    "Rebar Shape", "The Length A of Stirrup rebar").A = 200
        obj.addProperty("App::PropertyLength", "B",    "Rebar Shape", "The Length B of Stirrup rebar").B=400
        obj.addProperty("App::PropertyLength", "dia",    "Rebar Shape", "The diameter of Stirrup rebar").dia = 6
        obj.addProperty("App::PropertyEnumeration","Type","Rebar Shape","The Type of hook rebar")
        obj.Type = ['1','2','3']
    def execute(self,obj):
        A = obj.A; B = obj.B; dia = obj.dia
        R = 4*obj.dia /2.
        Rcos = R*cos(radians(45))
        l_hookcos = 6*obj.dia*cos(radians(45))
        pointslist = []
        if obj.Type=='1': # แบบงอฉาก
            pointslist.append(Vector(-A/2.,+B/2.-R-12*dia,0))
            pointslist.append(Vector(-A/2.,+B/2.,0))
            pointslist.append(Vector(+A/2.,+B/2.,0))
            pointslist.append(Vector(+A/2.,-B/2.,0))
            pointslist.append(Vector(-A/2.,-B/2.,+dia))
            pointslist.append(Vector(-A/2.,+B/2.,+dia))
            pointslist.append(Vector(-A/2.+R+12*dia,+B/2.,+dia))
        elif obj.Type=='2': # แบบงอขอ
            #Msg('Type=2\n')
            x = -A/2.; y =+B/2.
            dy = R + R* cos(radians(45))
            x1 = x + R - R* cos(radians(45))
            y1 = y - dy
            l_hook = 6*obj.dia*cos(radians(45))
            pointslist.append(Vector(x1+l_hook ,y1-l_hook,0))
            pointslist.append(Vector(x1-dy,y,0))
            #points.append(Vector(-A/2.,+B/2.,0))
            x1 = x + R + R* cos(radians(45))
            y1 = y - R + R* cos(radians(45))
            pointslist.append(Vector(x,y1+dy,+dia))
            pointslist.append(Vector(x1+l_hook,y1-l_hook,+dia))
        elif obj.Type=='3': # แบบงอข้าม
            x = -obj.A/2.; y =-obj.B/2.
            dx = R + R* cos(radians(45))
            dy = dx
            x1 = x + dx
            y1 = y + R - R* cos(radians(45))
            pointslist.append(FreeCAD.Vector(x1+l_hook,y1+l_hook,0))
            pointslist.append(FreeCAD.Vector(x,y1-dy,0))
            x = -obj.A/2.; y =+obj.B/2.
            pointslist.append(FreeCAD.Vector(x,y,0))
            pointslist.append(FreeCAD.Vector(+obj.A/2.,+obj.B/2.,0))
            pointslist.append(FreeCAD.Vector(+obj.A/2.,-obj.B/2.,0))
            pointslist.append(FreeCAD.Vector(-obj.A/2.,-obj.B/2.,+obj.dia))
            pointslist.append(FreeCAD.Vector(x,y1+dy,+obj.dia))
            pointslist.append(FreeCAD.Vector(x1+l_hook,y1-l_hook,+obj.dia))
        obj.Points = pointslist
        obj.Closed = False
        obj.MakeFace = False
        obj.Support = None
        Draft._Wire.execute(self,obj)
def makeTestColumn02():
    doc =FreeCAD.ActiveDocument
    b = 300
    t = b
    covering = 20
    dia = 15
    dia_stir = 6
    concrete = Arch.makeStructure(length=b,width=t,height=500.0)
    h_mainRebar = 750
    x = +b/2
    total_covering = covering + dia_stir + dia/2.
    gap = (b - 2*total_covering - dia*2 )/3.
    line1 = Draft.makeLine((x,x-total_covering,0) , (x,x-total_covering,h_mainRebar))
    rebar1.Base = line1
    rebar1.Label = 'CustomRebar'
    rebar1.Host = concrete
    rebar1.Amount = 4
    rebar1.Direction = (-1., 0., 0.)
    rebar1.Rounding = 2
    rebar1.OffsetStart =total_covering ; rebar1.OffsetEnd =total_covering
    rebar1.Role = u"Rebar"
    line2 = Draft.makeLine((x,-x+total_covering,0) , (x,-x+total_covering,h_mainRebar))
    rebar2.Base = line2
    rebar2.Label = 'CustomRebar'
    rebar2.Host = concrete
    rebar2.Amount = 4
    rebar2.Direction = (-1., 0., 0.)
    rebar2.Rounding = 2
    rebar2.OffsetStart =total_covering ; rebar2.OffsetEnd =total_covering
    rebar2.Role = u"Rebar"
    y = +b/2.-total_covering-gap-dia/2.
    line3 = Draft.makeLine((x,y,0) , (x,y,h_mainRebar))
    rebar3 = Arch.makeRebar(diameter = dia)
    rebar3.Base = line3
    rebar3.Label = 'CustomRebar'
    rebar3.Host = concrete
    rebar3.Amount = 2
    rebar3.Direction = (-1., 0., 0.)
    rebar3.Rounding = 2
    rebar3.OffsetStart =total_covering ; rebar3.OffsetEnd =total_covering
    rebar3.Role = u"Rebar"
    y = -b/2.+total_covering+gap+dia/2.
    line4 = Draft.makeLine((x,y,0) , (x,y,h_mainRebar))
    rebar4 = Arch.makeRebar(diameter = dia)
    rebar4.Base = line4
    rebar4.Label = 'CustomRebar'
    rebar4.Host = concrete
    rebar4.Amount = 2
    rebar4.Direction = (-1., 0., 0.)
    rebar4.Rounding = 2
    rebar4.OffsetStart =total_covering ; rebar4.OffsetEnd =total_covering
    rebar4.Role = u"Rebar"
    line5= doc.addObject("Part::Part2DObjectPython",'stirrup1')
    StirrupShape(line5)
    line5.Type = '2'
    line5.dia = dia_stir
    line5.Placement.Base = Vector(0,0,500+50)
    Draft._ViewProviderWire(line5.ViewObject)
    line5.A = b- 2*covering - dia_stir
    line5.B = b- 2*covering - dia_stir
    line5.MakeFace = False
    line5.FilletRadius = 2*dia_stir
    rebar5 = Arch.makeRebar(diameter = dia_stir)
    rebar5.Base = line5
    rebar5.Label = 'CustomRebar'
    rebar5.Host = concrete
    rebar5.Amount = 1
    rebar5.Direction = (-1., 0., 0.)
    rebar5.Rounding = 0
    rebar5.OffsetStart =0 ; rebar5.OffsetEnd =0
    rebar5.Role = u"Rebar"
    rebar5.ViewObject.ShapeColor = (0.667,0.000,0.000)
    line6= doc.addObject("Part::Part2DObjectPython",'stirrup2')
    StirrupShape(line6)
    line6.Type = '2'
    line6.dia = dia_stir
    line6.Placement.Base = Vector(0,0,500+50+dia_stir*2)
    line6.Placement.Rotation.Axis= Vector(0.,0.,1.)
    line6.Placement.Rotation.Angle= radians(-90)
    Draft._ViewProviderWire(line6.ViewObject)
    #Draft.rotate([line6], -90.0 ,Vector(0.,0.,0.),axis=Vector(0.,0.,1.),copy=False)
    line6.A = b- 2*covering - dia_stir -dia - 2*gap - dia_stir/2
    line6.B = b- 2*covering - dia_stir
    line6.MakeFace = False
    line6.FilletRadius = 2*dia_stir
    rebar6 = Arch.makeRebar(diameter = dia_stir)
    rebar6.Base = line6
    rebar6.Label = 'CustomRebar'
    rebar6.Host = concrete
    rebar6.Amount = 1
    rebar6.Direction = (-1., 0., 0.)
    rebar6.Rounding = 0
    rebar6.OffsetStart =0 ; rebar6.OffsetEnd =0
    rebar6.Role = u"Rebar"
    rebar6.ViewObject.ShapeColor = (0.667,0.000,0.000)
    line7= doc.addObject("Part::Part2DObjectPython",'stirrup3')
    StirrupShape(line7)
    line7.Type = '2'
    line7.dia = dia_stir
    line7.Placement.Base = Vector(0,0,500+50+dia_stir*4)
    line7.Placement.Rotation.Axis= Vector(0.,0.,1.)
    line7.Placement.Rotation.Angle= radians(180)
    Draft._ViewProviderWire(line7.ViewObject)
    line7.A = b- 2*covering - dia_stir -dia - 2*gap - dia_stir/2
    line7.B = b- 2*covering - dia_stir
    line7.MakeFace = False
    line7.FilletRadius = 2*dia_stir
    rebar7 = Arch.makeRebar(diameter = dia_stir)
    rebar7.Base = line7
    rebar7.Label = 'CustomRebar'
    rebar7.Host = concrete
    rebar7.Amount = 1
    rebar7.Direction = (-1., 0., 0.)
    rebar7.Rounding = 0
    rebar7.OffsetStart =0 ; rebar7.OffsetEnd =0
    rebar7.Role = u"Rebar"
    rebar7.ViewObject.ShapeColor = (0.667,0.000,0.000)
    makeTestColumn02()
    Msg('Done!!\n\n')
Rebar Addon: Commits on Jul 20, 2017
Version: 0.17.11616 (Git)
Hash: aba4338808178b508f3170237f205e0066a5b437
OCC version: 7.1.0
Hi @chakkree,
I have found a bug present in the above stirrup code.
This bug is coming when I change a diameter(dia property of the stirrup1) of the stirrup. However, I found a reason behind why this bug came. Actually, you have not trigger obj.FilletRadius = 2*obj.dia code in the execute function. Given below is the correct code:
   TestColumn02.py
   20 Jul 2017
import FreeCAD
import Arch
import Draft
# Custom DWire
# *** Prototype ***
        R = 4*obj.dia /2.
        pointslist = []
            #Msg('Type=2\n')
            x = -A/2.; y =+B/2.
            y1 = y - dy
            dy = dx
            x1 = x + dx
        obj.Closed = False
        obj.Support = None
    b = 300
    t = b
    covering = 20
    dia = 15
    dia_stir = 6
    h_mainRebar = 750
    x = +b/2
    rebar1.Base = line1
    rebar1.Amount = 4
    rebar1.Rounding = 2
    rebar2.Base = line2
    rebar2.Amount = 4
    rebar2.Rounding = 2
    rebar3.Base = line3
    rebar3.Amount = 2
    rebar3.Rounding = 2
    rebar4.Base = line4
    rebar4.Amount = 2
    rebar4.Rounding = 2
    StirrupShape(line5)
    line5.Type = '2'
    rebar5.Base = line5
    rebar5.Amount = 1
    rebar5.Rounding = 0
    StirrupShape(line6)
    line6.Type = '2'
    rebar6.Base = line6
    rebar6.Amount = 1
    rebar6.Rounding = 0
    StirrupShape(line7)
    line7.Type = '2'
    rebar7.Base = line7
    rebar7.Amount = 1
    rebar7.Rounding = 0
    makeTestColumn02()
    Msg('Done!!\n\n')
However, I like your approach. :) You first round the wire then pass it to the rebar object but I create a wire without rounding and then pass it to the rebar. The main difference in my and your's approach is that I have used rounding property of the rebar object. Below is the wire shape of the stirrup created with my approach.
Can you tell which approach is better one?
Thanks,
Amritpal Singh
Github, Like my work, sponsor me!
regis
Postby regis » Tue Jul 25, 2017 8:50 pm
A new round of testing, mostly looking at application on stairs.
github file link:
https://github.com/chopinregis/Youtube- ... 517f54c816
phpBB [video]
stair rebar test.fcstd
(508.34 KiB) Downloaded 22 times
Screenshot from 2017-07-25 16-48-22.png (777.03 KiB) Viewed 1133 times
chakkree
Postby chakkree » Wed Jul 26, 2017 2:34 am
That class is an old class from ArchRebar2. The class not clear for new ArchRebar, but I want to know that concept still can be used in new ArchRebar. Now, I'm not sure what is better. The main objective of Rebar is can get length property and total length property from creating report of rebar(rebar schedule or bar-cut list)
amrit3701
Postby amrit3701 » Wed Jul 26, 2017 12:04 pm
Hi @regis,
You are doing great. :) I have fixed a bug of expanded stirrup direction which only came on selecting the side face of a stirrup. I also noticed that your rebar add-on is not the latest one. Try to update it from addon manager because many new features you are missing ;).
Thanks,
Amritpal Singh
Postby Kunda1 » Wed Jul 26, 2017 12:07 pm
Maybe we should list the addon versions in the About FreeCAD dialogue ?
thschrader
Postby thschrader » Wed Jul 26, 2017 3:26 pm
@amritpal
@chakkree
In the link you will find a german company specialized on developing rebar tools.
Maybe you can find something for your "inspiration".
regards thomas
http://www.dicad.de/dicad_eng/news/2014 ... anung.html
sgrogan
Postby sgrogan » Wed Jul 26, 2017 9:09 pm
This should be handled by the add-ons installer. Either from meta-data in the package (in case it is installed with the .zip fallback) or using git-python.
"fight the good fight"
chakkree
Postby chakkree » Thu Jul 27, 2017 7:34 am
Test create footing using dialog.
My first dialog. :D
  TestFooting2.py
  27 Jul 2017
  https://github.com/FreeCAD/FreeCAD/blob/master/src/Mod/TemplatePyMod/TaskPanel.py
import FreeCAD
import Draft
import Arch
from PySide import QtGui,QtCore
import  UShapeRebar , Stirrup
class SquareFootingTaskPanel:
    def __init__(self):
        widget1 = QtGui.QWidget()
        widget1.setWindowTitle("Square Footing")
        self.lengthLabel = QtGui.QLabel(u"Lenght")
        self.Length = QtGui.QDoubleSpinBox()
        self.Length.setRange(1, 10000000.00)
        self.Length.setValue(1000)
        self.Length.setDecimals(0)
        self.Length.setSuffix(' mm')
        self.widthLabel = QtGui.QLabel(u"Width")
        self.Width = QtGui.QDoubleSpinBox()
        self.Width.setRange(1, 10000000.00)
        self.Width.setValue(1000)
        self.Width.setDecimals(0)
        self.Width.setSuffix('mm')
        self.heightLabel = QtGui.QLabel(u"Height")
        self.Height = QtGui.QDoubleSpinBox()
        self.Height.setRange(1, 10000000.00)
        self.Height.setValue(300)
        self.Height.setDecimals(0)
        self.Height.setSuffix(' mm')
        grid = QtGui.QGridLayout()
        grid.addWidget(self.lengthLabel, 1, 0)
        grid.addWidget(self.Length, 1, 1)
        #grid.addWidget(self.widthLabel, 2, 0)
        #grid.addWidget(self.Width, 2, 1)
        grid.addWidget(self.heightLabel, 3, 0)
        grid.addWidget(self.Height, 3, 1)
        widget1.setLayout(grid)
        widget2 = QtGui.QWidget()
        widget2.setWindowTitle("Reinforcement")
        grid2 = QtGui.QGridLayout()
        self.numRebarLabel = QtGui.QLabel(u"Num of Rebar")
        self.diaLabel = QtGui.QLabel(u"diameter")
        self.coveringLabel = QtGui.QLabel(u"Covering")
        grid2.addWidget(self.numRebarLabel, 1, 0)
        grid2.addWidget(self.diaLabel, 2, 0)
        grid2.addWidget(self.coveringLabel, 3, 0)
        self.numRebar = QtGui.QSpinBox()
        self.numRebar.setRange(1, 1000)
        self.numRebar.setValue(5)
        grid2.addWidget(self.numRebar, 1, 1)
        self.dia = QtGui.QDoubleSpinBox()
        self.dia.setRange(1, 100)
        self.dia.setValue(12)
        self.dia.setDecimals(1)
        self.dia.setSuffix(' mm')
        grid2.addWidget(self.dia, 2, 1)
        self.covering = QtGui.QDoubleSpinBox()
        self.covering.setRange(0, 300)
        self.covering.setValue(50)
        self.covering.setDecimals(1)
        self.covering.setSuffix(' mm')
        grid2.addWidget(self.covering, 3, 1)
        widget2.setLayout(grid2)
        self.form = [widget1,widget2]
    def accept(self):
        length = self.Length.value()
        height = self.Height.value()
        L,B,t = length,length,height
        num = self.numRebar.value()
        covering = self.covering.value()
        dia = self.dia.value()
        roundFactor = 2
        R = roundFactor*dia
        rebar1 = UShapeRebar.makeUShapeRebar(f_cover=covering+dia/2.+R, \
              b_cover=covering+dia/2.,  t_cover=covering, \
              r_cover=covering+dia/2., l_cover=covering+dia/2., diameter=dia,  \
              rounding=2, amount_spacing_check=True, amount_spacing_value=num, \
              orientation = "Bottom", structure = footing1, facename = 'Face1')
        rebar2 = UShapeRebar.makeUShapeRebar(f_cover=covering+dia/2.+R, \
              b_cover=covering+dia/2.+dia,  t_cover=covering, \
              rounding=roundFactor, amount_spacing_check=True, amount_spacing_value=num, \
              orientation = "Bottom", structure = footing1, facename = 'Face6')
        return True
    FreeCADGui.Control.showDialog(SquareFootingTaskPanel())
Rebar Addon: Commits on Jul 26, 2017(83 commits)
Version: 0.17.11659 (Git)
Hash: 37258b918def361c8f80b3e82a6a420904af1229
OCC version: 7.1.0
