Dev logs of Rebar Addon for FreeCAD - GSoC project
amrit3701
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
Postby amrit3701 » Sat Aug 05, 2017 7:10 pm
yorik wrote:
Thu Jun 01, 2017 6:44 pm
Hello everyone,
Here is my TODO task list which I will complete before final phase evaluation:
1. Complete circular stirrup (spiral) which Yorik posted it in his previous post in this thread.
2. Create wiki pages for all rebar shapes which I completed.
3. Add "Apply" button in all dialog boxes of rebar shapes.
4. Add user facility to give custom spacing when he/she creating rebar. Now user gives custom spacing after creating rebar with rebar tool.
5. Also, discuss with Yorik that can we add rebar tools as default FreeCAD feature.
Currently, I am working on task 1 which is 30 percent completed. I will share on the forum next week.
Regards,
Amritpal Singh
Github, Like my work, sponsor me!
amrit3701
Postby amrit3701 » Sun Aug 06, 2017 11:57 am
chakkree wrote:
Tue Jul 11, 2017 4:13 am
I try to coding for a circular column.
But spiral stirrup is not a smooth curve.
  Test Circular Column Rebbar
  11 July 2017
import FreeCAD
import Arch , Draft
from FreeCAD import Vector
from math import pi , sin , cos
def makeCircularColumn():
    dia_col = 300.0*2
    h_col = 5000
    doc = FreeCAD.ActiveDocument
    concShape = doc.addObject("Part::Cylinder","Concrete")
    concShape.Radius = dia_col/2
    concShape.Height = h_col
    column = Arch.makeStructure(concShape)
    column.ViewObject.Transparency = 80
    L = h_col+500
    iAngle = 0.0
    covering = 50
    dia = 20 # main rebar
    dia_stir = 16
    dx = covering+dia_stir+dia/2
    R = dia_col/2.  -dx  #dia_col-dx
    num = 8
    for i in range(0,num):
        iAngle = i*(2*pi)/num
        x = R* cos(iAngle)
        y = R* sin(iAngle)
        #Msg("%d x = %.1f , y=%.1f\n"%(i+1 , x,y))
        points=[Vector(x,y,0.0),
            Vector(x,y,L)]
        line = Draft.makeWire(points,closed=False,face=True,support=None)
        line.ViewObject.Visibility = False
        rebar1 = Arch.makeRebar(diameter = dia)
        rebar1.Base = line
        rebar1.Label = 'RebarMain%d'%(iAngle+1)
        rebar1.Host = column
        rebar1.Amount = 1
        rebar1.OffsetStart =0 ; rebar1.OffsetEnd =0
        rebar1.Role = u"Rebar"
    spacing = 150
    segment = 8*2
    #numCircular = h_col / spacing
    dx = covering+dia_stir/2
    dz = float(spacing) / segment
    z = 20
    R = dia_col/2.  -dx
    points = []
    #for n in range(0,numCircular):
    count = 1
    while (z<h_col):
        for i in range(0,segment):
            #Msg('count = %d , i=%d \n'%(count,i))
            iAngle = i*(2*pi)/segment
            x = R* cos(iAngle)
            y = R* sin(iAngle)
            points.append( Vector(x,y,z))
            z += dz
            count += 1
    line2 = Draft.makeWire(points,closed=False,face=True,support=None)
    line2.ViewObject.Visibility = False
    rebar2 = Arch.makeRebar(diameter = dia_stir)
    rebar2.Base = line2
    rebar2.Label = 'spiralStirrup'
    rebar2.Host = column
    rebar2.Amount = 1
    rebar2.OffsetStart =0 ; rebar1.OffsetEnd =0
    rebar2.Role = u"Rebar"
if __name__=="__main__":
    FreeCAD.ActiveDocument.recompute()
    Msg('Done!!\n\n')
Hi @chakkree,
Can you explain this "iAngle = i * (2 * math.pi) / edges"? It will be better if you share the sources which help to create circular stirrup.
Till now I added circular stirrup which will only work when a column is parallel is z-axis (i.e. vertical). You test it by updating rebar tool.
Regards,
Amritpal Singh
chakkree
Postby chakkree » Sun Aug 06, 2017 2:04 pm
Hi @chakkree,
Regards,
This code is not quite good. It's not real curve.
It's approximate point of a line.
I think spring or helix macro will guide to use a real curve, for example, B-spline.
chakkree
Postby chakkree » Sun Aug 06, 2017 2:45 pm
may be try Part.makeHelix
Spring.py -> http://iesensor.com/FreeCADDoc/0.16-dev ... ource.html
amrit3701
Postby amrit3701 » Sun Aug 06, 2017 5:21 pm
Yes, I know that we are making helix / circle from small straight lines but if I used Part::Helix as the base of rebar object then rebar shape is not cylindrical. I also shared this bug with Yorik and he told me that I can start with that and if later on, we find a way to use the helix.
Shape of Rebar when I set Part::Helix as a base object.
Shape of Rebar when I set wire (small straight lines) as a base object.
Regards,
Amritpal Singh
regis
Postby regis » Sun Aug 06, 2017 9:41 pm
good progress, looking good,
chakkree
Postby chakkree » Tue Aug 08, 2017 3:57 am
Try to use Part.arc
But it has some problems.
1) arc C4 is not show
2) It can not pass part.wire to rebar object for base object. May be to pass data to Draft.wire.
  Test Circular Column Rebar
  8 Aug 2017
import FreeCAD
import Arch , Draft
from math import pi , sin , cos, radians
def makeOneLoop(r=150 , p=150 , n=1 ):
    v1 = Vector(r,0,0)
    v2 = Vector(r*cos(radians(45)),r*cos(radians(45)),p/4.0/2.0)
    v3 = Vector(0,r,p/4.0)
    C1 = Part.Arc(v1,v2,v3)
    v1 = Vector(0,r,p/4.0)
    v2 = Vector(-r*cos(radians(45)),r*cos(radians(45)),p/8.0*3)
    v3 = Vector(-r,0,p/4.0*2)
    C2 = Part.Arc(v1,v2,v3)
    v1 = Vector(-r,0,p/4.0*2)
    v2 = Vector(-r*cos(radians(45)),-r*cos(radians(45)),p/8.0*5)
    v3 = Vector(0,-r,p/4.0*3)
    C3 = Part.Arc(v1,v2,v3)
    v1 = Vector(0,-r,p/4.0*3)
    v2 = Vector(r*cos(radians(45)),-r*cos(radians(45)),p/8.0*7)
    v3 = Vector(r,0,p)
    C4 = Part.Arc(v1,v2,v3)
    S1 = Part.Shape([C1,C2,C3,C4])
    W = Part.Wire(S1.Edges)
    Part.show(W)
    makeOneLoop()
    Msg('Done!!\n\n')
yorik
Site Admin
Postby yorik » Tue Aug 08, 2017 2:19 pm
It is possible to use makePipeShell with a helix:
Screenshot from 2017-08-08 11-11-44.png (216.79 KiB) Viewed 1300 times
helix = App.ActiveDocument.addObject("Part::Helix","Helix")
helix.Pitch=150
helix.Height=300
helix.Radius=1000
helix.Angle=0.00
helix.LocalCoord=0
helix.Style=1
# not sure what LocalCoord and Style are for...
# to create a tangential circle:
wire = helix.Shape
edge = wire.Edges[0]
basepoint = edge.Vertexes[0].Point
tangent = edge.tangentAt(0)
circle = Part.makeCircle(50,basepoint,tangent)
# now the pipe works
pipe = wire.makePipeShell([circle],True, False,2)
helix.fcstd
(49.44 KiB) Downloaded 23 times
regis
Postby regis » Tue Aug 08, 2017 2:23 pm
helix.Pitch=150
helix.Height=300
helix.Radius=1000
helix.Angle=0.00
helix.LocalCoord=0
helix.Style=1
wire = helix.Shape
bravo, smoother output, this gives a better 2d and 3d printing out put on techdraw as well,
amrit3701
Postby amrit3701 » Wed Aug 09, 2017 3:51 pm
Hello everyone,
Yeah! I have completed my 3rd task. Now, all rebar dialog boxes have "Apply" button.
Thanks,
Amritpal Singh
