Dev logs of Rebar Addon for FreeCAD - GSoC project
thschrader
Re: Dev logs of Rebar Addon for FreeCAD - GSoC project
Postby thschrader » Tue Jul 11, 2017 7:53 am
@chakkree.
Wowwww!
I am more than impressed, believe me!
Cant test your code, I did my last coding when I was as a student long time ago...
code: fortran 77 :geek:
thomas
Postby chrisb » Tue Jul 11, 2017 8:10 am
Yeah, coding is what has been done in the old days. Nowadays we use programming languages :)
regis
Postby regis » Tue Jul 11, 2017 11:06 am
can someone explain to me why the stirrup toold and the u and straight rebar tool don't work for me? when it seems it is working on everyone else's?
thschrader
Postby thschrader » Tue Jul 11, 2017 11:36 am
I have the same problem.
thomas
thschrader
Postby thschrader » Tue Jul 11, 2017 1:04 pm
Installed rebar-tools and did some playing.
1. the straight/u-shape/stirrup dialogs open, but no reaction to input.
2. drawing a full circle on top of column gives rebar-error
3. drawing 2x half-circle gives a flat face
4. drawing spline works
the rest is done with the "normal" rebar-tool. parametric works.
Look at the console: would be a nice option, when the lower edges of the
shear-reinforcement bars could have the same distance to the inclined surface.
thomas
rebar_test001.FCStd
(302.69 KiB) Downloaded 11 times
all done with
Version: 0.17.11528 (Git)
Hash: d31be3117de386b4f6cd3444e0b330db56dc6ba2
Python version: 2.7.8
OCC version: 7.1.0
amrit3701
Postby amrit3701 » Tue Jul 11, 2017 2:07 pm
Can you paste the output of the report view (View -> Panels -> Report View) when you click on the "Ok" button of rebar dialog box?
Regards,
thschrader
Postby thschrader » Tue Jul 11, 2017 2:31 pm
Regards,
greetings thomas
OCC version: 7.1.0
regis
Postby regis » Tue Jul 11, 2017 2:44 pm
Regards,
Cannot identified shape or from which base object sturctural element is derived
phpBB [video]
Screenshot from 2017-07-11 10-40-33.png (223.86 KiB) Viewed 531 times
amrit3701
Postby amrit3701 » Tue Jul 11, 2017 3:03 pm
thschrader wrote:
Thanks for this,
Current rebar addon does not work properly when structural element is derived from a wire. But for testing purpose, you can create structure element directly from structure button (Arch -> Structure). I will surely add support when structural element is derived from any object this week.
Regards,
amrit3701
Postby amrit3701 » Tue Jul 11, 2017 3:12 pm
Hello everyone,
I have added custom spacing button in a straight rebar dialog box. To try rebar distribution, you can update it from FreeCAD Addon manager. At first, a custom spacing button is set to disable but it automatically enables when you try to edit rebar (double click on rebar). Below are the screenshots of rebar distribution:
RebarDistribution.svg
(33.25 KiB) Downloaded 222 times
