[Solved] Feature #0003031: Draft To Sketch should handle bsplines and beziers
Postby Kunda1 » Thu Jun 15, 2017 12:36 pm
issue #0003031: Draft To Sketch should handle bsplines and beziers
Opening an exclusive legit discussion thread to generate discussion about this Feature. The inspiration for the ticket and idea started in https://forum.freecadweb.org/viewtopic. ... 21#p174038
NormandC
Re: Feature #0003031: Draft To Sketch should handle bsplines and beziers
Postby NormandC » Sat Jun 17, 2017 5:44 pm
The only discussion there can be is, who will step up and implement it? ;)
Draft workbench has BSplines and Bézier curves.
Sketch now has B-spline support.
Draft has a Draft2Sketch conversion utility that is only partially working since it strips B-splines and Bézier from the conversion process. This is a legitimate feature request and one that could have indirect uses, like DXF support when exporting sketches containing B-splines...
yorik
Site Admin
Postby yorik » Mon Jun 19, 2017 2:54 pm
Yes draft2sketch should definitely handle it. TBH I was (lazily as always) waiting for things to stabilize in Sketch bsplines , since Abdullah seemed still working on it, but it seems that the python interface won't change anymore.
I'll do this when I have a moment. But bezier curves won't be handled. Or there is a way to convert them to bsplines?
Chris_G
Postby Chris_G » Mon Jun 19, 2017 3:08 pm
At the geometry level, you have :
bspline = bezier.toBSpline(bezier.FirstParameter, bezier.LastParameter)
Postby chrisb » Mon Jun 19, 2017 8:24 pm
That is good news, since it improves the compatibility between FreeCAD and inkscape, which I like for it's image tracing capabilities and its usability of bezier curves. The user interface of the Sketcher's bsplines is very promising as well.
Postby chrisb » Sun Nov 05, 2017 12:38 pm
Works lik a charm.
Re: [Solved] Feature #0003031: Draft To Sketch should handle bsplines and beziers
Postby Kunda1 » Sun Nov 05, 2017 12:41 pm
