Alternative GUI for FreeCAD: Overlayed Layout (Devs needed)
Post by Kunda1 »
Just a heads up to anyone out there that is industrious and interested...
Here is an interface that @ickby created in 2014/5 that uses Qt5 actually used qt4 and was based on qml.
phpBB [video]
The sources are on a branch in his github repo. Will post as a follow up.
Edit:
source (recently updated 6/22/17): https://github.com/FreeCAD/FreeCAD/comp ... kby:layout
https://github.com/ickby/FreeCAD_sf_master/tree/layout
ickby
Re: Alternative GUI for FreeCAD
Post by ickby »
It actually used qt4 and was based on qml. I stopped working on this as qt5 was needed to do real interfaces in qml, and that was not available back than in FreeCAD.
But the code is horrible, I suck at JavaScript :)
kkremitzki
Post by kkremitzki »
ickby wrote: Wed Jun 21, 2017 7:47 pm But the code is horrible, I suck at JavaScript :)
It's for the best, as they say "Be careful what you get good at doin' 'cause you'll be doin' it for the rest of your life."
Post by Kunda1 »
ickby wrote: Wed Jun 21, 2017 7:47 pm It actually used qt4 and was based on qml. I stopped working on this as qt5 was needed to do real interfaces in qml, and that was not available back than in FreeCAD.
Either way it's a great proof of concept!
Chris_G
Post by Chris_G »
I looked at this video many times, and I'd love to see this revived, now that Qt5 is almost there ...
Post by Kunda1 »
Is it worth rebasing the branch so if someone out there wants to take a stab at implementing this overlay approach?
ickby
Post by ickby »
I have quite some doubts that this will work after all that time... but out of curiosity I may try that this evening :)
Post by Kunda1 »
ickby wrote: Thu Jun 22, 2017 11:39 am I have quite some doubts that this will work after all that time... but out of curiosity I may try that this evening :)
Fun! Fantastic!
ickby
Post by ickby »
hah I actually made it work again :) Needed some hours as the QT5 changes have been significant in FreeCAD master, and most likely I messed quite some things up for qt5, but here we go (qt4 only):
So if someone wants to go on with this the proof of concept is there, and I happily guide you through. But be aware, there is a LOT of work to be done :)
Post by Kunda1 »
ickby wrote: Fri Jun 23, 2017 4:26 am hah I actually made it work again :) Needed some hours as the QT5 changes have been significant in FreeCAD master, and most likely I messed quite some things up for qt5...
@ickby that is Awesome news!
Could you push the rebase to your github repo?
Also would you consider bullet pointing what would need to be done to get it working on Qt5?
