Utility to inspect OpenCascade models
Re: Utility to inspect OpenCascade models
My experiment with the Defeaturing tool:
https://peertube.mastodon.host/videos/w ... d8e6783872
A difficult one, created with Cimatron from user Polymer, in this video Polymer uses face repair tools:
Next video from user Polymer using Cimatron defeaturing tools:
easyw-fc and his defeaturing workbench:
OCC defeaturing is not as good as the tool from Cimatron and need a bit more improvement.
Great, Analysis Situs is running on Wine hq.
How to change the appearance, because it's very bright?Re: Utility to inspect OpenCascade models
A small update for anyone who follows:
Available since today (ver. 0.3.0). The color can be changed from the parameter editor. Also, some more B-Rep inspection functions are not available in both GUI and console.freecad-heini-1 wrote: ↑Sun Oct 14, 2018 10:09 am How to change the appearance, because it's very bright?
This tool is too much different from FC to directly embed it. At the same time, if you find some piece of code useful, just take it away.
FOSS CAD model inspection utility and prototyping framework: http://analysissitus.org
Yet another update: I have finally compiled Analysis Situs on Linux (Ubuntu18_04) and it seems to work pretty much as expected. If anybody wants to give it a try, the master branch of the Git repo is Linux-ready (though, cmake scripts might deserve some more polishing; also there is a big deal of compilation warnings).
Hi @QuaoarQuaoar wrote: ↑Sat Jan 18, 2020 9:47 pm Yet another update: I have finally compiled Analysis Situs on Linux (Ubuntu18_04) and it seems to work pretty much as expected. If anybody wants to give it a try, the master branch of the Git repo is Linux-ready (though, cmake scripts might deserve some more polishing; also there is a big deal of compilation warnings).
I've tried to build it on linux but I got some errors...
here my steps:
cd AnalysisSitus
mkdir build
cd ~/AnalysisSitus/build
cmake ../
-- The CXX compiler identification is GNU 7.4.0
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Analysis Situs VERSION_MAJOR: 0
-- Analysis Situs VERSION_MINOR: 3
-- Analysis Situs VERSION_PATCH: 2
CMake Error at CMakeLists.txt:35 (message):
... root 3rdparty directory was not found.
Please, set 3RDPARTY_DIR variable.
-- Configuring incomplete, errors occurred!
Thx
Maurice
I tried to gather some notes here: https://docs.google.com/document/d/1JWb ... bzZJM/edit#
Honestly, I am a newbie in linux, so the compilation process can likely be simplified or at least polished. I will be working to improve the configuration, and any criticism is very welcome,
- tanderson69
ok
Normally on debian based distros, locally built packages get installed to '/usr/local/'. My build processes became much smoother, once I quit fighting this.
Dependencies that are real specific, like ActiveData, I would make git submodules and do a recursive clone on the parent repo. This will clone everything at once and make sure the different git repos are synced.
did you really need to build tcl/tk. I have never had to do that for occt?
IMHO: Have you tried meson build? In any situation that I can, I have replaced cmake with meson and been a lot happier!
Hi @QuaoarQuaoar wrote: ↑Wed Jan 22, 2020 12:34 pm I tried to gather some notes here: https://docs.google.com/document/d/1JWb ... bzZJM/edit#
I'm trying to build it using cmake and the terminal... this is much handy to reproduce the building in different PCs...
(the same is suggested for FreeCAD [Single command for Python 3 and Qt5 https://www.freecadweb.org/wiki/CompileOnUnix])
here my initial attempts: (please note that I can already build FreeCAD)
git clone https://gitlab.com/ssv/AnalysisSitus.git
cd AnalysisSitus
mkdir build
sudo apt install build-essential
sudo apt install qtcreator
sudo apt install qt5-default
sudo apt-get install libqt5x11extras5-dev
cmake -D 3RDPARTY_DIR=/usr/lib ../
cd ~
git clone https://gitlab.kitware.com/vtk/vtk.git
cd vtk
git checkout tags/v8.2.0
sudo apt-get install libxt-dev
cmake -D 3RDPARTY_DIR=/usr/lib -D 3RDPARTY_vtk_LIBRARY_DIR=../../vtk ../
cd ~
git clone https://gitlab.com/ssv/active-data.git
-- Processing Qt 3-rd party
-- ... Qt cmake configuration at /usr/lib/x86_64-linux-gnu/cmake/Qt5
-- ... Qt libraries: /usr/lib/x86_64-linux-gnu/cmake/Qt5
-- Processing active_data 3-rd party
-- ... Searching for active_data in /usr/lib for compiler gxx and bitness 64
-- ... Found: active_data_DIR_NAME =
-- ... Warning: directory for active_data 3-rd party not found
-- ... Sub-dir hint for includes is empty
-- ... Hint on header is ActData.h, so let's search for its containing directory with suffix hint inc;include
-- ... Warning: include dir seems bad!
-- ... Active Data Include dirs:
-- ... Active Data Library dirs: ../../active-data
-- ... Active Data Binary dirs:
CMake Error at cmake/asitus_ActiveData.cmake:18 (set):
set given invalid arguments for CACHE mode.
CMakeLists.txt:42 (include)
-- ... Active Data Debug Library dirs: ../../active-data
-- ... Active Data Debug Binary dirs:
-- Processing Eigen 3-rd party
-- ... Searching for eigen in /usr/lib for compiler gxx and bitness 64
-- ... Found: EIGEN_DIR =
-- ... Eigen dir: /usr/lib
-- Processing vtk 3-rd party
-- ... Searching for vtk in /usr/lib for compiler gxx and bitness 64
-- ... Found: vtk_DIR_NAME =
-- ... Warning: directory for vtk 3-rd party not found
-- ... Hint on header is vtkAlgorithm.h, so let's search for its containing directory with suffix hint inc;include
-- ... VTK Include dir is not conventional
-- ... VTK Include dirs: /include/vtk-8.2
-- ... VTK Library dirs: ../../vtk
-- ... VTK Binary dirs:
CMake Error at cmake/asitus_VTK.cmake:21 (set):
CMakeLists.txt:48 (include)
-- ... VTK Debug Library dirs: ../../vtk
-- ... VTK Debug Binary dirs:
-- Processing OCCT 3-rd party
-- ... Searching for OCCT in /usr/lib for compiler gxx and bitness 64
-- ... Found: OCCT_DIR_NAME =
-- ... Warning: directory for OCCT 3-rd party not found
-- ... Hint on header is Standard.hxx, so let's search for its containing directory with suffix hint inc;include
-- ... Attempting to find path by hint library "TKernel"
-- ... Hint suffix for searching of libraries is lin64/gxx/lib;lib;lib/intel64/gxx
-- ... OCCT Include dirs:
-- ... OCCT Library dirs:
-- ... OCCT Binary dirs:
CMake Error at cmake/asitus_OCCT.cmake:7 (string):
string sub-command REPLACE requires at least four arguments.
CMakeLists.txt:51 (include)
-- ... OCCT Debug Library dirs:
-- ... OCCT Debug Binary dirs:
-- ... OCCT libraries:
-- Processing tcl 3-rd party
-- ... Hint on header is tcl.h, so let's search for its containing directory with suffix hint inc;include
-- ... Attempting to find path by hint library "tcl86"
-- Processing Inno Setup 3-rd party
-- ... Searching for innosetup in /usr/lib for compiler gxx and bitness 64
-- ... Found: INNOSETUP_DIR =
-- ... Inno Setup dir: /usr/lib/
-- ... Unsetting 3RDPARTY_mobius_DIR
-- ... Unsetting 3RDPARTY_mobius_INCLUDE_DIR
-- ... Unsetting 3RDPARTY_mobius_LIBRARY_DIR
-- ... Unsetting 3RDPARTY_mobius_DLL_DIR
CMake Error at CMakeLists.txt:123 (message):
NOT FOUND: 3RDPARTY_active_data_INCLUDE_DIR 3RDPARTY_OCCT_INCLUDE_DIR
3RDPARTY_OCCT_LIBRARY_DIR 3RDPARTY_tcl_INCLUDE_DIR 3RDPARTY_tcl_LIBRARY_DIR
See also "/home/mau/AnalysisSitus/build/CMakeFiles/CMakeOutput.log".
Maurice
Hi tanderson69, and thanks for your comments. I will try to organize Active Data as a git submodule indeed. As for Tcl/Tk, Tk is not required but Tcl is needed because there's an embedded Tcl console which makes much sense for rapid prototyping. It's pretty much like OpenCascade's Draw console but with different commands. I have never heard about Meson, will check ittanderson69 wrote: ↑Wed Jan 22, 2020 4:04 pm Normally on debian based distros, locally built packages get installed to '/usr/local/'. My build processes became much smoother, once I quit fighting this.
Hello Maurice. Thanks for giving it a try and sorry for my crappy configuration scripts, it's too bad if you wasted much time on it. I will try to make it more conventional and smart, and your link to FreeCAD's guide is of much help.
I will check your log and come up to you soon.
