OBELISK
renatorivo
Re: OBELISK
Postby renatorivo » Mon Sep 04, 2017 7:36 pm
Jee-Bee wrote:
Sun Sep 03, 2017 12:16 pm
In that case i ask on the developer forum.
@Jee-Bee in your file I can not make Datum and Sketch objects visible. To create a loft sketches must be visible, I think.
I have a very simple file to test Loft applied to Draft. If you want to try it and see if it works in Mac.
draft-loft.FCStd
(15.75 KiB) Downloaded 20 times
OS: Windows 8.1
Version: 0.17.11958 (Git)
Hash: c9957b8a98e71b2a69c71b9f92acf1cf01afcc35
Python version: 2.7.8
OCC version: 7.1.0
Locale: Italian/Italy (it_IT)
Renato
Re: OBELISK
Postby chrisb » Mon Sep 04, 2017 11:43 pm
I can create the loft on MacOS. I have to select the top face before starting the loft. It is not possible to select the edges as first section.
OS: Mac OS X
Version: 0.17.11919 (Git)
Branch: (detached from fccb5db)
Hash: fccb5dbc87b919164610296adc96aa8b4fe4825e
Python version: 2.7.13
Qt version: 5.6.2
OCC version: 7.1.0
renatorivo
Re: OBELISK
Postby renatorivo » Tue Sep 05, 2017 6:32 am
ok, it works like this.
Now there are two examples where you can select the sketch.
draft-loft2 the top is fixed
Draft-loft3 the top follows the top face of Draft
draft-loft2.FCStd
(18.29 KiB) Downloaded 19 times
draft-loft3.FCStd
(18.25 KiB) Downloaded 20 times
If you can do this I will say everything works.
Renato
Re: OBELISK
Postby chrisb » Tue Sep 05, 2017 8:14 am
I am not sure what this means and I don't see a difference in the lofts of draft-loft2 and draft-loft3, so perhaps it helps if I tell what I have done in both models:
- deleted the existing loft
- make both sketches visible
- selected the lower sketch
- additive loft
- added section upper sketch
-> works ok.
- the same but selected upper sketch first
- added section lower sketch
-> works ok
pekkio
Re: OBELISK
Postby pekkio » Tue Sep 05, 2017 10:28 am
This is what I wanted to make and the result is fine. Obelisk created with loft.
obelisco.FCStd
(485.67 KiB) Downloaded 20 times
renatorivo
Re: OBELISK
Postby renatorivo » Tue Sep 05, 2017 11:53 am
This shows that Sweep and Loft also work on Mac OS X.
In your file, only Fusion001 is not a valid shape.
