[proposal] Add option to disable turntable rotation constraint
Re: [proposal] Add option to disable turntable rotation constraint
Yeah, you are probably trolling me - constantly misreading stuff. Good job.
Hi everyone,
I would like to make a code proposal for this feature as it is still needed.
I did it localy by replacing the Turntable code for testing and it seems to work (there is still a very small unwanted rotation that makes the z axis not vertical over time but the feeling is closer to Blender anyway).
I then tried to add an Orbit Style but the new option won't show in the drop-down.
Can I have some advice on where to look for a solution ?
Here is my branch:
https://github.com/nab-os/FreeCAD/tree/ ... rbit_style
Here is my branch:
Hi and welcome to the forum!
https://forum.freecadweb.org/viewforum.php?f=10
I understand why you posted here and it is sensible as a follow up. Alas, you are asking for developers advice and I'm not sure they are watching this forum. So you may consider to post there a complete version of your question.
Oh, thank you for the redirection.
I posted there if someone wants to follow the proposal:
https://forum.freecadweb.org/viewtopic.php?f=10&t=73276
Edit:
The post has been deleted
You can follow the proposal directly on my repository:
Edit:
