Thanks!
Bug tracker update thread: v2.21.0
Re: Bug tracker update thread: v2.13.1
- kkremitzki
Re: Bug tracker update thread: v2.15.0
I've updated the bug tracker to 2.15.0. There's also a new version of the Source Integration plugin out, which I've installed, so keep an eye out for different behavior there.
Thank you very much !kkremitzki wrote: ↑Wed Jun 27, 2018 10:13 am I've updated the bug tracker to 2.15.0. There's also a new version of the Source Integration plugin out, which I've installed, so keep an eye out for different behavior there.
Thanks Kurt! I hope the integration plugin works better...
- kkremitzki
Re: Bug tracker update thread: v2.16.0
Bug tracker updated to 2.16.0, and the source integration has been updated again as well.
Source Integration is still not working, case in point https://freecadweb.org/tracker/view.php?id=3038#c11564
The source integration seems to be working, but not updated: https://freecadweb.org/tracker/plugin.p ... /list&id=2
I also see this in the source integration's "manage" screen: Maybe there is something to do with that "rate limit"... Although we should be well under the limit https://developer.github.com/v3/#rate-limiting
Let's keep watching the repo page above to see if it still updates or not at all...
- kkremitzki
