Bug #1951: Draft workbench preferences snap settings does not use "units" settings
openBrain
Re: Bug #1951: Draft workbench preferences snap settings does not use "units" settings
Post by openBrain »
wmayer wrote: Ping
@wmayer I'd like to analyse why the 'onChange' function isn't correctly called when I 'Attach' the instance to a parameter group (while the attachment itself works, and all works fine in a macro). Could you please indicate in which function the attached instances are called when a parameter is changed ?
Thanks
carlopav
Post by carlopav »
openBrain wrote: Mon Jan 24, 2022 4:26 pm * Regarding DocumentObserver, but grid management in Draft (through the 'Snapper' tracker) is too complex (chunky ? :P) for me to achieve something working smoothly without having to deep dive into it
If the purpose is to set the grid visible when a new document is opened while the Draft workbench is already active, this dirty solution works for me:
    def slotActivateDocument(self, doc):
        """Called when a document is activated"""
        if FreeCADGui.Snapper:
            from PySide import QtCore
            QtCore.QTimer.singleShot(2000, FreeCADGui.Snapper.setGrid)
I guess because the 3DView is not already available when a new document is activated? :?: The solution is really dirty, it is only meant for debugging purposes. Perhaps we should observe the creation of a new view and not of a new document? In fact the grid is not displayed also when you open a new view of an already opened document.... Edit: is there a way to observe when "Gui.ActiveDocument.ActiveView" changes?
I think FreeCADGui.Snapper should always be available, also before the workbench is activated, can you reproduce a case when it does not exhist or it is None?
openBrain
Post by openBrain »
carlopav wrote: Tue Jan 25, 2022 9:55 pmEdit: is there a way to observe when "Gui.ActiveDocument.ActiveView" changes?
Unfortunately not. I also had a look at this and there is no slot in DocumentObserver for this. I had a quick look to implement it, but it's over my spare time ATM.
Maybe we could ping @wmayer about this.
AFAIR no. 'Snapper' is always there.
But 'Snapper.grid' changes a lot : non existing, None, instantiated,...
yorik
Founder
Post by yorik »
Yes, this is all old, legacy code from a time I wasn't very good at coding :oops: The whole grid and snapping system could definitely be reworked.
Indeed many startup procedures happen before the 3D view is on. Firing a Qt timer is how we usually solved this in the past, for ex. in the Tux module.
I can look at the onChange function too.. Which macro has it successfully working?
openBrain
Post by openBrain »
yorik wrote: Wed Jan 26, 2022 11:58 am Yes, this is all old, legacy code from a time I wasn't very good at coding :oops: The whole grid and snapping system could definitely be reworked.
It also looks like it was tweaked for feature improvement several times. Some refactor could be good, but I guess the main issue for me was my lack of knowledge on this part of code. :)
Yes, saw that in the past when fixing something in Tux. I'll refactor it when I get some spare time. ;)
However here it indeed probably needs to have an event when view is ready. I think having a slot in Gui::DocumentObserver when a view is created (fired when the view is ready) would be beneficial. Eventually one when a view is closed too, but IMO less useful. I'll ping @wmayer soon to probe how he feels about implementing this. :P
Ouch, I'm with my mobile now. Will post it here in the coming day.
openBrain
Post by openBrain »
yorik wrote: Wed Jan 26, 2022 11:58 am I can look at the onChange function too.. Which macro has it successfully working?
Here the macro I used for testing "as is" :
class obs:
    def onChange(self, arg1, arg2):
        print(f"{arg1=} // {arg2=}")
ob = obs()
grp = App.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft")
grp.Attach(ob)
Then to test you modify any Draft parameter (either in preferences or in parameter editor).
I had another issue that may eventually solved at the same time : each parameter is called twice when changing in preferences. ;)
Founder
Post by wmayer »
openBrain wrote: Mon Jan 24, 2022 9:26 am Here's the basic fix as a PR : https://github.com/FreeCAD/FreeCAD/pull/5427
The PR lacks of the unit property (replace suffix with unit):
          <property name="unit">
           <string>mm</string>
          </property>
Several UI pages of the Draft wb are added to the resource file Draft_rc.py. So, after the change you still have to update Draft_rc.py:
pyside2-rcc <Path>/Mod/Draft/Resources/Draft.qrc -o <Path>/Mod/Draft/Draft_rc.py
Because preferences-draftsnap.ui is loaded by PreferenceUiForm an additional fix was needed: git commit 8da66398ad
Now there is still an odd behaviour of PrefQuantitySpinBox that of prefPath and prefEntry that latter is ignored. PrefQuantitySpinBox saves a history of several values (by default up to 5) and saves them as Hist0, Hist1, ... The context-menu of the widgets lists all values of the history.
Founder
Post by wmayer »
openBrain wrote: Tue Jan 25, 2022 5:11 pm @wmayer I'd like to analyse why the 'onChange' function isn't correctly called when I 'Attach' the instance to a parameter group (while the attachment itself works, and all works fine in a macro). Could you please indicate in which function the attached instances are called when a parameter is changed ?
Thanks
https://github.com/FreeCAD/FreeCAD/blob ... ver.h#L173
carlopav
Post by carlopav »
wmayer wrote: Sat Jan 29, 2022 7:10 am
@wmayer, how do you feel about having the possibility for the Gui Document Observer to be notified when a view is Activated?
Founder
Post by wmayer »
Making the document observer aware of view changes doesn't fit very well in this concept. You better connect a slot function to the Qt signal subWindowActivated of the QMdiArea class: https://doc.qt.io/qt-5/qmdiarea.html#subWindowActivated
from PySide2 import QtWidgets
def myFunction(args):
  print (args)
mw = Gui.getMainWindow()
mdi = mw.findChild(QtWidgets.QMdiArea)
mdi.subWindowActivated.connect(myFunction)
