STL conversion
sp9rqa
STL conversion
Postby sp9rqa » Mon Feb 05, 2018 12:26 pm
I have tiny problem with "stl" conversion.
FC create meshes but not create "Solid from shell".
Example file: left_mainv3.stl in https://www.thingiverse.com/thing:2043600/#files project.
shell=App.ActiveDocument.left_mainv3001.Shape
>>> if shell.ShapeType != 'Shell': raise RuntimeError('Part object is not a shell')
>>> _=Part.Solid(shell)
>>> if _.isNull(): raise RuntimeError('Failed to create solid')
>>> App.ActiveDocument.addObject('Part::Feature','Solid').Shape=_.removeSplitter()
>>> del _
Why?
Krzysztof
Re: STL conversion
Postby Kunda1 » Mon Feb 05, 2018 3:47 pm
please always post you Help > About FreeCAD > Copy to clipboard info
and please put code in
code brackets
sp9rqa
Re: STL conversion
Postby sp9rqa » Mon Feb 05, 2018 5:26 pm
I have tested some last versions, there is always the same result.
OS: Debian GNU/Linux testing (buster)
Version: 0.17.13205 (Git)
Build type: None
Hash: 4ef00d7be4658a1fdc905699ede2860e002d9996
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Locale: Polish/Poland (pl_PL)
Re: STL conversion
Postby NormandC » Tue Feb 06, 2018 3:40 am
Why?
I'm asking myself the same thing: why did you post in Open discussion, when this is clearly a help request?
Help requests should be posted in the "Help on using FreeCAD" forum. If your question is about python scripting, then use the python scripting forum.
The problem is that you assume that you have a valid manifold mesh. But the fact is, you cannot be sure of it. An outstanding proportion of stl files on Thingiverse are simply badly made.
The first problem is that your mesh is actually composed of multiple meshes. Each raised letter is a separate mesh. Check your shape with Part CheckGeometry. You can separate them with Arch --> Utilities --> Split mesh.
But then you'll see that the first mesh for the body, when converted to a shape, forms an invalid shell. If you check the mesh with "Meshes --> Analyse --> Evaluate & Repair Mesh...", it will tell you there are 15 degenerated faces.
But you are lucky: here, the repair function works. Usually, it destroys the mesh further, by deleting the broken faces and leaving a mesh with missing faces.
Attached is a FCStd file with the main body converted to shape, refined then converted to solid. You'll have to repeat the process with the letters.
left_mainv3.fcstd
(328.73 KiB) Downloaded 15 times
