Whiteboard for v0.18
Re: Whiteboard for v0.18
Let ShapeBinder be aware of the placement of Part; at least as an option.
Thanks wf for summing up all these ideas. Could you please replace "allowing to have multiple parts in the PartDesign workbench" with "temporarily allowing to have multiple parts in the PartDesign workbench". This is just to make it clearer in the case the file is taken out of the context it was generated (this forum topic).
Thanks,
Gaël
Make an universal Debian folder that works on both Debian and Ubuntu and merge to FreeCAD master.
"fight the good fight"
- wandererfan
tsk, tsk. nudging the "no challenging of ideas" rule.
- wandererfan
today's update.
Any thoughts on how long to prolong the "idea generating" phase? There seem to be some common threads emerging so we should be getting near the end.
How about Friday 2018-02-16 for end of this phase with analysis and debate to start on the weekend?
Native support for non-metric units in the GUI.
Current "expression system" works, but has two problems. One is simply that almost every numerical entry requires clicking on the fx button and then closing the expression in a multi-step process.
The other problem is that every constraint in a sketch shows up in the dependency graph as an expression, often greatly expanding each element. Makes it much more difficult to get useful information from the dependency graph.
This may be inherent to the basic libraries used in FreeCAD, but I have never encountered another multi-unit-system program that requires the expression style entry. Typically one just sets the defaults in preferences and never needs to think about it again.
Gene
Gene
easy hooking/callbacks for plugins, see https://forum.freecadweb.org/viewtopic.php?f=22&t=25221
it would be really nice to be able to be notified as a plugin on opening a new document, closing, ...
quite similar: for an angle constraint, be able to select which of the two angles you like to constraint (outer or inner).
+1 for me. Thanks for this wondererfan. This also lines up with the GSoC timeline:https://developers.google.com/open-source/gsoc/timelinewandererfan wrote: ↑Wed Feb 14, 2018 3:52 pm How about Friday 2018-02-16 for end of this phase with analysis and debate to start on the weekend?
ref:https://www.freecadweb.org/wiki/Google_Summer_of_Code
How should we debate? Separate threads by category? Maybe this is not granular enough, but there are so many cross dependencies.
@wandererfan, your project management skills will be stressed, I'm sure
OK then, my idea then is "no default use of MMB" since its not available by default on a very significant number of systems! Better?
