I report some elements that are not translatable in version 0.17 13325
PART
Main menu: Measure
Part menu: Primitives, Join + sub, Split + sub, Compound + Compound filter, Attachment...
Also, the description in the Join drop-down menu is missing
ARCH
Arch menu: Utilities, Axis tools, Panel tools, Material tools, Pipe tools
DRAFT
Draft menu: Utilities, Snapping
SKETCHER
Main menu: Profiles + sub
Sketch menu: Sketcher B-spline tools
OpenSCAD
To view the translations, first set the English language, then set the desired language, otherwise the translations do not appear. The WB seems untranslated.
OS: Windows 8.1
Version: 0.17.13325 (Git)
Hash: 77c1fc59e4732d52e04a2846f83fb01a839bc589
Python version: 2.7.14
OCC version: 7.1.0
Locale: Italian/Italy (it_IT)
Renato
v0.17 UI translation
Re: v0.17 UI translation
Kunda1 wrote:ping
Good catch Renato.yorik wrote:ping
They are there in v0.16renatorivo wrote: ↑Sat Feb 24, 2018 3:22 pm Also, the description in the Join drop-down menu is missing
I can reproduce with my existing FreeCAD profile. But with new user.cfg and system.cfg files, FreeCAD loads in French, and the OpenSCAD menu displays in French as it should at first load.renatorivo wrote: ↑Sat Feb 24, 2018 3:22 pm OpenSCAD
OS: Ubuntu 16.04.4 LTS
Build type: None
Python version: 2.7.12
OCC version: 7.1.0
Locale: French/Canada (fr_CA)
Also
the description in the Properties is not translated
Forgot
Arch -> Rebar tools + sub
My impression, and I won't speak for yorik, but this is what I've been told by yorik is that in regards to workbenches and other part of FC that need translation...we wait till after 0.17 is released. This is because we've already pushed translation changes for the translators several times in this cycle. So I imagine that most of the needs will be bumped to after 0.17 is released.
I also was thinking it may be an idea to have the crowdin translations available via the addon manager...where updates to translations could be pulled in if the user chooses so. That way they don't have to wait for the next release to get the most up to date translations. (See https://github.com/FreeCAD/FreeCAD-addons/issues/68 )
Edit: See issue #3372
@renatorivo lets coordinate getting these translations merged now that 0.17 has been release?
PM me
