integration between ose-piping-workbench and flamingo-wb
rus
Re: integration between ose-piping-workbench and flamingo-wb
Post by rus »
Geoplace wrote: Mon Apr 08, 2019 1:55 am I think that is best to focus to make it work with v0.18 with python 3 and Qt5 and make a note to say that it's not backwards compatible.
I read that V0.17 will not be supported by FreeCAD devolopers.
Joel_graff wrote: Mon Apr 08, 2019 2:37 am ...
I would agree with @GeoPlace. Support for both in v0.18 is simply to smooth the transition to Qt5 / Py3 only in 0.19. And 0.19 will probably be released in a year. Unless it's an easy thing to accommodate the older frameworks, I would just ignore them since there will be no reason to support them once 0.19 is released.
OK. Then I will focus on v0.18
rus
Post by rus »
kisolre wrote: Mon Apr 08, 2019 6:57 pm I tried to install and run that workbench ut when I try to switch to if I get the following error:
No module named 'Coupling'
  File "<string>", line 45, in Initialize
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\ose-piping-workbench\OsePipingCommands.py", line 28, in <module>
    import OsePiping.CouplingGui as CouplingGui
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\ose-piping-workbench\OsePiping\CouplingGui.py", line 6, in <module>
    import Coupling
There is a file OsePiping\Coupling.py but it is not found. Any ideas why is that?
I am already working on a fix.
rus
Post by rus »
I fixed a lot of imports. I hope now ose-piping WB will also work in windows.
kisolre
Post by kisolre »
rus wrote: Sat Apr 13, 2019 9:13 am I fixed a lot of imports. I hope now ose-piping WB will also work in windows.
A quick test shows it is working. But here is another broken import:
Init: Processing command line files
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\ose-piping-workbench\OsePiping\CreatePartGui.py", line 239, in accept
    self.acceptCreationMode()
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\ose-piping-workbench\OsePiping\CreatePartGui.py", line 210, in acceptCreationMode
    self.params.document, self.params.table, partName, outputType)
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\ose-piping-workbench\OsePiping\SweepElbowGui.py", line 31, in createNewPart
    part = builder.create(partName, outputType)
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\ose-piping-workbench\OsePiping\SweepElbow.py", line 317, in create
    import OsePiping.FlSweepElbow as FlSweepElbow
  File "C:\Users\Wivern\AppData\Roaming\FreeCAD\Mod\ose-piping-workbench\OsePiping\FlSweepElbow.py", line 9, in <module>
    import SweepElbow as SweepElbowMod
ModuleNotFoundError: No module named 'SweepElbow'
OS: Windows 8.1
Version: 0.19.16267 (Git)
Hash: ddb335cfe057336f1958d68126bb0471328d735c
Python version: 3.6.6
Qt version: 5.6.2
rus
Post by rus »
kisolre wrote: Sat Apr 13, 2019 11:20 am A quick test shows it is working. But here is another broken import:
Thank you for the bug report I fixed it. I just tests the WB under windows 10 it can create flamingo parts :D now !
rus
Post by rus »
I fixed two other bugs:
  • "I cannot place pipes into not-90° elbows.".
  • "Cannot place pipe and fittings into modified fittings.".
I think I need to learn how to do proper Visualization for pipe parts. All the connections are based on Ports. Here is the description https://wiki.opensourceecology.de/OSE_P ... ench_Ports
It is like a SnapPoints from Arch but with orientation (Rotation + orientation) in Arch https://www.freecadweb.org/wiki/Arch_Pipe/en
Maybe I should change the name to SnapPoint too? @Yorik what do you think?
yorik wrote: Wed Aug 24, 2016 2:30 pm
