3DXML File
akeyokey
3DXML File
Post by akeyokey »
I would like to know if there is a way to open 3DXML file using a macro or a trick :?:
Thanks :!:
OS: Windows 7
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
NormandC
Re: 3DXML File
Post by NormandC »
3DXML is a proprietary file format invented by Dassault Systèmes. It is only supported by Dassault Systèmes software.
It's apparently a zip container so you could extract its content. But it's doubtful you'll be able to do anything with it.
https://en.wikipedia.org/wiki/3DXML
akeyokey
Re: 3DXML File
Post by akeyokey »
NormandC wrote: Thu Apr 19, 2018 2:07 am Hi,
Ok Thanks, I will try to extract and see what I can do with it.
mantielero
Re: 3DXML File
Post by mantielero »
Sorry to unbury a dead thread.
Just to point out that it looks like the format is documented here.
It woud be great that FreeCAD were capable of reading this files, that are it pretty common in order to share geometries.
aerospaceweeb
Re: 3DXML File
Post by aerospaceweeb »
Hey so, as usual, Dassault's documentation is just as crappy as every other thing they create.
That being said though, it's xml, and I think we could do something here.
# Just make the 3DRep file into something I can word censored read
# read the whole 3DRep file.
with open('TessPart_5.3DRep') as f:
    lines = f.readlines()
f.close()
# write it out again with linebreaks in the right places
characters = lines[1]
outfile = ''
for i in range(len(characters)):
    # check that not at end
    if i == len(characters)-1:
        continue
    elif characters[i] == ">" and characters[i+1] == "<":
        outfile += ">\n"
    else:
        outfile += characters[i]
# open output file and put word censored in it
o = open('outfile.txt','w')
o.write(str(outfile))
o.close()
there's some code which linebreaks the default terrible 3dxml files into something with proper damn linebreaks, and here's a test file I'm working on.
TessPart_5.3DRep.txt
(488.46 KiB) Downloaded 96 times
I've only worked on FEM module stuff before so I don't really have any clue how to do freeCAD gui stuff, but I'm about to google what proper parametric 3d file formats do exist that are easy to write to and start playing around there.
aerospaceweeb
Re: 3DXML File
Hey I got something to work.
Using the following code, I can now read a BREP file and import all of the edges in the models as wires.
import FreeCAD, Part, Fem
from PySide import QtGui
import os
import sys
import re
Vector = App.Vector
def beautify_xml(input_filename): # {{{
    """Just make the 3DRep file into something I can word censored read
    with open(input_filename) as f:
    f.close()
    outfile = ''
            continue
            outfile += ">\n"
        else:
    o = open('outfile.xml','w')
    o.close()
    # make sure I'm on linux
    if sys.platform != "linux":
        raise ValueError("Need to be using linux in order to get xmllint")
    # do the bash command xmllint --format outfile.txt
    os.system("xmllint --format outfile.xml > outfile2.xml")
    os.system("rm outfile.xml")
    os.system("mv outfile2.xml outfile.xml")
    # now read the good file back in with readlines
    with open("outfile.xml") as f:
    f.close
    return lines
def main(): # {{{
    """ take a 3DRep file and try to get it into freecad
    # get the xml content from the user
    input_filename=QtGui.QFileDialog.getOpenFileName()[0]
    # check to make sure the file is a 3DRep file
    if input_filename.split('/')[-1].split('.')[-1] != '3DRep':
        raise ValueError('Need to select a 3DRep file.')
    xml_content = beautify_xml(input_filename)
    # let's see if we can't make the PolygonalRepType into wires
    # find every line where "PolygonalRepType" starts
    data = []
    i = 0
    while i < len(xml_content)-1:
        line = xml_content[i]
        if "PolygonalRepType" in line:
            i += 1
            if "<Edges>" in line:
                escape = False
                while escape == False:
                    i += 1
                    if "</Edges>" in line:
                        escape = True
                    elif "<Polyline vertices=" in line:
                        data.append(line)
        i += 1
    # now have the data for the edges
    # go through it and make the lines for FreeCAD
    vecs = []
    for line in data:
        point_data = line.split('"')[1]
        point_data = point_data.split(',')
        curve = []
        for point in point_data:
            coords = point.split(' ')
            x = float(coords[0])
            y = float(coords[1])
            z = float(coords[2])
            curve.append((x,y,z))
        vecs.append(curve)
    for v in vecs:
        a = Part.makePolygon(v)
        Part.show(a)
    return
if __name__ == '__main__':
    main()
I'm going to now try and figure out what I can do with the faces.
heda
Re: 3DXML File
Post by heda »
cool - could turn out to be the start of something really useful,
when it comes to python, one can always assume that there is some sort of higher level interface to do basic processing, it is just a matter of finding it :-).
for prettify of xml one can use
from xml.dom import minidom
with open('pretty.xml', 'wt') as f:
    f.write(minidom.parse('myfile.xml').toprettyxml())
if one just wants to extract info from an xml file, the xml.etree.ElementTree battery included module is useful for that (and not much point in prettify then, since it is easy enough to explore/extract nodes from the tree as is). This works great if the xml is well formed, not so well if it is malformed - then one should go to other libraries that are more forgiving on correctness.
specifically for fc, one could use lxml instead, since fc already has it as an dependency.
using batteries included I think your code could be drastically shorter and still do the same :-)
keithsloan52
Re: 3DXML File
Post by keithsloan52 »
heda wrote: Sun Sep 26, 2021 8:17 am
I would strongly recommend that you use lxml to parse the file https://lxml.de and as pointed out several other parts of FreeCAD already make use of the lxml library.
heda
Re: 3DXML File
Post by heda »
as inspiration for an lxml variant, here is one with py std-lib,
works on the attached file.
import Part
import xml.etree.ElementTree as ET
filename, filt = QtGui.QFileDialog.getOpenFileName(filter='*.3DRep')
if not filename:
doc = App.ActiveDocument
tree = ET.parse(filename)
root = tree.getroot()
floatify = lambda p: tuple((float(i) for i in p.split()))
for xroot in root.findall('{*}Root/{*}Rep'):
    edges = xroot.find('{*}Rep/{*}Edges')
    group = doc.addObject('App::DocumentObjectGroup','Group')
    for poly in edges:
        verts = [floatify(v) for v in poly.get('vertices').split(',')]
        pl = Part.makePolygon(verts)
        obj = doc.addObject('Part::Feature', 'Shape')
        obj.Shape = pl
        group.addObject(obj)
doc.recompute()
keithsloan52
Re: 3DXML File
heda wrote: Mon Sep 27, 2021 9:01 pm as inspiration for an lxml variant, here is one with py std-lib,
Except that is using xml NOT lxml which is faster and has more option.
Try changing
to
 import lxml.etree.ElementTree as ET
