Feature #1632: Allow entering of diameter instead of radius for circle radius constraint
Re: Feature #1632: Allow entering of diameter instead of radius for circle radius constraint
Postby chrisb » Fri Jun 15, 2018 5:23 pm
This looks perfect! I will test when it is in master and close the ticket.
dbecad
Postby dbecad » Fri Jun 15, 2018 5:40 pm
abdullah wrote:
Fri Jun 15, 2018 3:30 pm
Once you are there, I think going to single dimension tool is a piece of cake. I do in fact like this way of constraining.
If you say so :D
That would be awesome to have one icon, one key for switching and avoid most back and forth between the sketch and the tool-bar. Even better use the same key-shortcut to select the tool and switch between constraints and you've got a killer efficient constraining workflow.
Once again, thanks for bringing us all these advances!
Cheers
