issue #3484: Open paths are closed upon upgrade
Please weigh in on this ticket.
Please also test related issue #3483 Simple paths cannot be upgraded
Bug #3484: Open paths are closed upon upgrade
Re: Bug #3484: Open paths are closed upon upgrade
How to reproduce as taken from issue #3484:
This is a pic of the paths as provided by the person who reported the bug:
Upon using Draft > Upgrade on the path using FreeCAD 0.17 I can confirm the behavior, and using 0.18 I get a hard crash.
Although the user posted an expected result, I don't know if that is what should be expected after using Draft > Upgrade on it, and after Import it does display in the 3D view:
To avoid confusion I deleted the last 3 paths and the numerals from the original file, here is only the first curve:
OS: Ubuntu 16.04.4 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.13522 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.12
OCC version: 7.2.0
Version: 0.18.13971 (Git)
Build type: None
Hash: 8e4dd8ca8496595d4718dc24c872f7ed668b2521
OCC version: 7.2.0
1. Create an SVG file with a single path comprising three nodes (see also bug 0003483).
2. Import the file into the Draft workbench as geometry.
3. Select the path and use the upgrade tool.
Expected result:
The path is converted to a Wire (or a Block, or other object that can be displayed in the Drawing workbench) as it is.
Actual result:
The path is converted to a Wire object and closed.
Build type: None
OCC version: 7.2.0
Build type: None
OCC version: 7.2.0
https://github.com/FreeCAD/FreeCAD/blob ... t.py#L3671
The result is a feature and not a bug. Need we a parameter to disable this feature?
# special case, we have only one open wire. We close it, unless it has only 1 edge!"
elif (len(openwires) == 1) and (not faces) and (not loneedges):
result = closeWire(objects[0])
if result: msg(translate("draft", "Found 1 open wire: closing it")+"\n")
- path_bug.gif (47.18 KiB) Viewed 927 times
