An example of Gordon Surface based upon OCC
microelly2
Re: An example of Gordon Surface based upon OCC
Post by microelly2 »
one profile has the false direction but it works fine.
red is the result
green is S1
brown is S2
and blue is S3
I made this video with my example to see the differences of these helper shapes
phpBB [video]
the short but good article about gordon surfaces is here:
http://old.cescg.org/CESCG99/MKuklisova/node1.html
freecad-heini-1
Post by freecad-heini-1 »
Whow Thomas, very nice. Please can you try to create a gordon surface with m experiments to design the tide-bottle in Freecad:
tide_bottle_gordon.fcstd
(115.19 KiB) Downloaded 111 times
hammax
Post by hammax »
… after installing last CurvesWB-update (7) and turning my stern-profile by placement z=180° it works.
But: I had constructed my hull frames by copying from a single starting frame and modification, there should be no fish-twist.
All original placement data were ok.
Maybe the new grid sorting algorithm wants it in this special form.
microelly2
freecad-heini-1 wrote: Thu Jul 12, 2018 7:22 pm Whow Thomas, very nice. Please can you try to create a gordon surface with m experiments to design the tide-bottle in Freecad:
I had to model the circle and the ellipse as beziers,
here are the sketches and curves
and here the surface
freecad-heini-1
microelly2 wrote: Fri Jul 13, 2018 7:38 am
Hi Thomas,
what about the tool from the curves-wb to join the selected Edges into Bspline curves?
Are this kind of bspline curves usable with your gordon surface tool?
Best regards
Wilfried
microelly2
freecad-heini-1 wrote: Fri Jul 13, 2018 7:44 am Hi Thomas,
Best regards
Wilfried
it is really not a big deal
and I have already the methods to convert most of the surfaces to bspline surfaces,
and now its the time to do it with curves too.
I allways use at a last step to convet the bsplines to multiplicity 3 knots, that means to bezier objects which are easier to edit
and all my methods in the editor work on this base.
So I see no compatibility problem in future. Any curve and surface should have a way to become a bspline if it is needed to perfom free forming actions.
The idea of the Gordon surfaces I had in background for the way to reconstruct shoes from scan: slice the point cloud, convert the slices to beziers with same structure, create a gordon surface from the slice grid. The big benefit of the gorden is the S3 term which gives better results than the loft and the sweeps with one or 2 sweep pathes.
https://youtu.be/4-S1P9MAA04
freecad-heini-1
Thank you Thomas for your answer.
Industrial designer mostly provide 2d drawings with dimensions and views in three or more view.
So the common way is to sketch the curves with this dimensions and not freehand.
To design freeform surfaces, the common way is to create the curves in the sketcher using lines and arcs and bspline curves. In some cases it make sense to convert lines and arcs with the curves-wb tool "join the selected Edges into Bspline curves to a joinCurve feature".
With the option corner-break false you can reduce knots and inbetween faces to reach a nice face. All this steps are full parametric. That means, if I change the sketch, the joinCurve will update automatically and the face as well.
What about your workflow. Is it full parametric? Is it possible to use sketcher bsplines and joinCurve and Lattice2 sublink edges?
Best regards
Wilfried
hammax
Post by hammax »
Hi Chris,
after your todays fixing of the "closed surface bug"
the Gordon feature doesn't work any more.
(Neither in TIGL-test nor on my hull-test.)
FC.18.14061 on Win10-32
Chris_G
Post by Chris_G »
I had to add a dependency to python-numpy.
Isn't it bundled in your version of FC ?
What is the result of this command in the python console :
import numpy
EDIT : I also forgot to remove an unused dependency to scipy.
What is the result of :
import scipy
If you get an error here, please try to update CurvesWB.
hammax
Post by hammax »
… numpy is in my package
but scipy is missing (with that I had already earlier version problems) - this should be a task of the FC18dev-package.
In the TIGL-file the following items don't work with the newest update
Full_Nacelle
Fuselage
Heli_Body
Spiral_Wing
