An example of Gordon Surface based upon OCC
freecad-heini-1
Re: An example of Gordon Surface based upon OCC
Post by freecad-heini-1 »
Chris_G wrote: Wed Nov 14, 2018 9:14 am The good news is that I found were the bug is happening.
The bad news is that it is located in the most complex function, dealing with "matrix solving", that is way over my poor math skills.
So I don't know how I will be able to fix that ... :cry:
What about to ask user rainman110, Martin from Cologne Germany?
microelly2
Post by microelly2 »
hammax wrote: Wed Nov 14, 2018 6:44 am … I see new features updated for GordonSurface in the CurvesWB.
I am trying to fix Gordon surface.
Currently, the algorithm is only partially working, and produces surfaces that have far too much control points.
The smartest and most important part of the TiGL algorithm is about preparing and reparametrizing the curves before feeding them to the actual Gordon algo.
I realized that these optimization functions were actually skipped in my implementation (and broken BTW).
The simplest workaround should be to run the method with ribs which have the same structure: number of poles,multiplicities and the same degree.
any two curves can be refined to such a common structure.
Chris_G
Post by Chris_G »
freecad-heini-1 wrote: Wed Nov 14, 2018 9:23 am What about to ask user rainman110, Martin from Cologne Germany?
Well ... I am not very keen on disturbing people.
And I see it as a good opportunity to learn these matrix things first.
Then, if I fail, I might ask for help.
microelly2 wrote: Wed Nov 14, 2018 9:27 am The simplest workaround should be to run the method with ribs which have the same structure: number of poles,multiplicities and the same degree.
That's not enough. The curves must also be reparametrized, so that they become isoCurves of the future surface.
That's all the beauty of the original algorithm : it does this hard job for us.
And even outside of the Gordon surface context, the reparametrizing function offers great functionalities :
- imagine you have a list of points, and you want to fit a curve on them.
- you can set some of the points to be interpolated, while the others will be approximated
- and you can choose the degree, and the number of control points !
So this is a very interesting mix between interpolation and approximation.
microelly2
Chris_G wrote: Wed Nov 14, 2018 9:59 am And even outside of the Gordon surface context, the reparametrizing function offers great functionalities :
Would be an interesting tool.
How the user will control which points are approximated and which are interpolation anchors?
My idea at the moment is to define bezier with parametric control points and the tangent direction I calculate with least square against a point cloud.
https://youtu.be/kPrQq4UOnR4
Chris_G
Post by Chris_G »
Good news : I think I managed to fix a couple of bugs !
The resulting surfaces are now almost identical to the one produced by the C++ TiGL algo.
hammax
Post by hammax »
… yes, now it works also with the interpolated curves
hammax
Post by hammax »
… answering gflorent's mail:
An updated ships' hull with gordon surface => very easy and straightforward from
https://forum.freecadweb.org/viewtopic. ... 10#p244083
Maybe look also here: https://forum.freecadweb.org/viewtopic. ... 63#p269050
GordonS_Test.FCStd
FC.18.15208
(22.82 KiB) Downloaded 80 times
freecad-heini-1
Chris_G wrote: Wed Nov 14, 2018 6:18 pm Good news : I think I managed to fix a couple of bugs !
Hi Chris,
thank you so much. Indeed you are reporting great news.
Best regards
Wilfried
gflorent
Post by gflorent »
I am starting with the Curves WB. Installed it via the Addons Manager on FC 0.17 13528 on Win 10. I create a BSpline curve with the "Create a BSpline curve" command and then, while it is selected, I click the "Create an editable spline from selected edges" in the hope to be able to modify it later via the control points. Then FreeCAD crashes and closes. Is it the right way to make a BSpline editable? Does anyone know of a good tutorial to get started?
Chris_G
Post by Chris_G »
gflorent wrote: Mon Nov 19, 2018 7:37 pm I am starting with the Curves WB. Installed it via the Addons Manager on FC 0.17 13528 on Win 10. I create a BSpline curve with the "Create a BSpline curve" command and then, while it is selected, I click the "Create an editable spline from selected edges" in the hope to be able to modify it later via the control points. Then FreeCAD crashes and closes. Is it the right way to make a BSpline editable? Does anyone know of a good tutorial to get started?
CurvesWB is an """EXPERIMENTAL""" workbench.
Some tools are not working very good.
These 2 tools you tried should not be used. I should remove them from the toolbar.
For an editable BSpline, you'd better use Sketcher, or Draft.
