An example of Gordon Surface based upon OCC
Re: An example of Gordon Surface based upon OCC
Postby chrisb » Wed Sep 05, 2018 10:51 pm
rainman110 wrote:
Wed Sep 05, 2018 7:36 pm
I am the developer of TiGL and implemented the gordon surface algorithm with my student merlin.
Thanks for making it public.
GlouGlou
Postby GlouGlou » Sun Nov 11, 2018 10:40 am
Hi. How to avoid twisted surface?
I've tried to change the order of selection for profiles or guides, but without result.
twisted.FCStd
(18.95 KiB) Downloaded 26 times
microelly2
Postby microelly2 » Sun Nov 11, 2018 10:33 pm
You gave to flip the direction of one rib curve
freecad-heini-1
Postby freecad-heini-1 » Mon Nov 12, 2018 8:03 am
And how?
Chris_G
Postby Chris_G » Mon Nov 12, 2018 8:25 am
You have to flip the direction of one rib curve
I am pretty sure the algorithm is supposed to take care of curve orientation by itself.
I have introduced several bugs in my python port.
But I'm afraid I'll gave great difficulties to find them.
hammax
Postby hammax » Mon Nov 12, 2018 4:08 pm
… there is no source from where you get the JoinCurves and therefore no possibility to correct/flip them.
But if you use interpolated curves from the endpoints of the JoinCurves in equal directions
the GordonSurface does not twist.
twisted_2.FCStd
FC.18.15169
(32.24 KiB) Downloaded 30 times
GlouGlou
Postby GlouGlou » Mon Nov 12, 2018 8:00 pm
@hammax: You just swapped guides with profiles. :D
GlouGlou
Postby GlouGlou » Mon Nov 12, 2018 8:02 pm
With not to do that manually with a option?
I finally change the direction of a sketch and the gordon came right. ;)
And able to finish this Rhino model (or something looking like ;) )
https://form2fab.com/wp-content/uploads ... ique_4.jpg
gordonRight.FCStd
(13.99 KiB) Downloaded 28 times
hammax
Postby hammax » Wed Nov 14, 2018 6:44 am
… I see new features updated for GordonSurface in the CurvesWB.
My trial was to use FrenetTN for Sketcher planes creating new profiles on existing profiles.
twisted_3.FCStd
FC.18.15190
(42.93 KiB) Downloaded 28 times
Chris_G
Postby Chris_G » Wed Nov 14, 2018 9:14 am
I am trying to fix Gordon surface.
Currently, the algorithm is only partially working, and produces surfaces that have far too much control points.
The smartest and most important part of the TiGL algorithm is about preparing and reparametrizing the curves before feeding them to the actual Gordon algo.
I realized that these optimization functions were actually skipped in my implementation (and broken BTW).
The good news is that I found were the bug is happening.
The bad news is that it is located in the most complex function, dealing with "matrix solving", that is way over my poor math skills.
So I don't know how I will be able to fix that ... :cry:
