An example of Gordon Surface based upon OCC
gflorent
Re: An example of Gordon Surface based upon OCC
Postby gflorent » Mon Nov 19, 2018 7:52 pm
For an experimental workbench, the support is better than for a commercial one ! Getting an answer in 2 minutes ! Wow ! Thanks for the tip, I will try following your advice ... Keep up the great work.
EDIT : it works great now, using BSplines made with Sketcher!
hammax
Postby hammax » Tue Nov 20, 2018 6:40 am
… repeatedly experimenting with the spline tools in CurvesWB
https://forum.freecadweb.org/viewtopic. ... 18#p269509
I don't fully understand it .
But modifying a simple straight line generated with the 2 spline tools,
in data tab you can form a 3D-spline and change its coordinates.
The combined projection /curves tool (in between the spline tools) working with sketcher splines,
is much better to understand and to control for us aero- and hydrodynamic body designers….
GlouGlou
Postby GlouGlou » Sat Dec 08, 2018 5:41 pm
Body made of pipeshell and handle with a gordon surface.
From Catia made with Freecad. ;)
microelly2
Postby microelly2 » Sat Dec 08, 2018 7:32 pm
nice to see this example for real life use case
GlouGlou
Postby GlouGlou » Sat Dec 15, 2018 5:03 pm
Gordon crash Freecad when making a gordon with the whole guides and make a inverted surface when I try to make 4 separated gordon. :roll:
gordoncrash.FCStd
(300.19 KiB) Downloaded 19 times
Chris_G
Postby Chris_G » Sat Dec 15, 2018 6:06 pm
Thanks for the bug report, I'll look at it when I get free time.
GlouGlou
Postby GlouGlou » Sun Dec 16, 2018 1:36 pm
there're no bug by slicing the bottom circle into 4 arcs. ;)
GlouGlou
Postby GlouGlou » Mon Dec 17, 2018 6:27 pm
A plastic bottle using gordon surfaces ans pipeshell. ;)
GlouGlou
Postby GlouGlou » Fri Dec 28, 2018 3:44 pm
Trying to make a hull, the gordon surface come with something more. :roll:
Do you have any idea about this issue? How to manage that?
GordonHull.FCStd
(263.16 KiB) Downloaded 20 times
saso
Postby saso » Fri Dec 28, 2018 4:18 pm
Did you see JoinCurve023?
