As an example, create a rectangle in Sketcher, click either the Horizontal Length Constraint or Vertical Length Constraint tool:
and select the appropriate edge. The Insert Length dialog window opens, prompting the user for input:
All ok so far, but following is what I'd like to see changed.
If the user wants to use an Expression, the user has to click the f(x) button, and then the Insert Length dialog window displays a sub-window containing an additional set of Cancel / Ok buttons (really Discard / Ok buttons):
In order to use an Expression, the user:
- clicks the f(x) button and inputs the Expression
- clicks the sub-window Ok button to accept the Expression,
- clicks the Insert length window Ok button to apply the Constraint.
This way the user simply keys the input into the corresponding input area and clicks Ok. I'd like the current behavior of the Result, along with the auto-complete suggestions, to remain.
Comments?
Oops - forgot to include:
OS: Ubuntu 16.04.4 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.14078 (Git)
Build type: None
Hash: be5e93ddfe29d49a4b1c02e7119b1f926549ccce
Python version: 2.7.12
