[/quote]
Can you write your step-by-step process to recreate the conditions of this phenomena that you're asking about ?
[/quote]
Quite simple..
In a Linux terminal :
wget https://framagit.org/MarcusFecit/Tigres ... e_10mm.dxf
wget https://framagit.org/MarcusFecit/LibreC ... FreeCad.py
chmod +x LibreCadToFreeCad.py
./LibreCadToFreeCad.py -i frame_10mm.dxf | freecad -c
Now it's more than 30 hours that this process runs on my machine and FreeCAD has only processed 1470 from 2442 lines.
You can replace the last line by these 2:
./LibreCadToFreeCad.py -i frame_10mm.dxf -o frame_10mm.fcpy
cat frame_10mm.fcpy | freecad -c
Doing so you'll see that the process from my script is very fast and that FreeCAD is slowing after swallowing about 150L, and then more an more.
LibreCad To FreeCad importing tool
Re: LibreCad To FreeCad importing tool
Marc BERLIOUX
Marc BERLIOUX
Yea, I can confirm the slowdown on:MarcX wrote: ↑Thu Oct 11, 2018 4:14 pm
./FreeCAD_0.18.14959.glibc2.17-x86_64.AppImage
OS: "Manjaro Linux"
Version: 0.18.14959 (Git) AppImage
Hash: ff05101b68dc9a7d1e70dd69544f14ac8598a433
Python version: 2.7.6
Qt version: 4.8.6
The process of my DXF is now finished after 44 hours. The FreeCAD's sketch is OK and contains:
- 831 Elements
- 1601 Constraints
The sketch is very long to open and each action on an element takes a very long time and 100% of a CPU core time.
Is there something I can do to make FreeCAD use all the processor cores ?
Marc BERLIOUX
Marc BERLIOUX
Hi friends,
I have an issue with FreeCAD's python console, I don't know if it's a bug or a feature:
if I paste a line in the console in order to create a document name with dashes, like:
App.newDocument("test-support")
the document is created without problem and appears in the document tree with the correct name, but it seems to be internally renamed using underscores instead of dashes:
>>> App.setActiveDocument("test_support")
>>> App.ActiveDocument=App.getDocument("test_support")
>>> Gui.ActiveDocument=Gui.getDocument("test_support")
Is it a bug or is it the normal behaviour ?
Marc BERLIOUX
Marc BERLIOUX
Bonjour,
I also give a hint in the Readme to process blocks.
Update !
Repository Reminder:
https://framagit.org/MarcusFecit/LibreCadToFreeCad
git clone https://framagit.org/MarcusFecit/LibreCadToFreeCad
git pull
CU
I've fixed the problem of dashes in document or layer names that were generating errors in FreeCAD's Python console. I suppose they were treated as the minus symbol.
Update !
git pull
CU
Marc BERLIOUX
Marc BERLIOUX
Just do it once again, I've made a few changes and a bug fix
git pull
Marc BERLIOUX
Marc BERLIOUX
