Here is a way to get Tree and Tasks working together without tab switching. Goto View-Panels and enable Tree view and Combo view. Put the Tree view far Left and overlay the Combo view over the Tree view (see pic and file) to conserve space. Keep the Task tab selected in the Combo view unless you need to adjust properties.
What you get from this is a smooth operating design experience, most all clicks are related to getting work done instead of tab switching all the time. Some key things to notice; FreeCAD does most of the switching between panels anyway so having these two windows overlapping does no harm, I think it takes less effort to design. What do you think?
I know sometimes the windows pop full screen but you get used to knowing where not to click. Also, it might be a bit more effort to adjust properties, that might be a good thing. You do lose maybe 5% of the modeling area but alot of it is over-lapping, I think it's worth it to see all the extra data. I attached a file so hopefully you can open it and try it.
Maybe this is just an example for the GUI update.
Maybe a better GUI workflow, no code changes, much less tab switching
- tree_combo.FCStd
- (19.75 KiB) Downloaded 26 times
- combo_tree3.JPG (86.89 KiB) Viewed 775 times
Re: Maybe a better GUI workflow, no code changes, much less tab switching
This discussion which a large portion is IMHO essentially regarding 'scarcity of screen real-estate' reminds me of ickby's awesome proof of concept frameless UI
https://forum.freecadweb.org/viewtopic.php?f=8&t=23053
Though there are bigger fish to fry, this is still an amazing goal to achieve.
As long as it's configurable I don't really mind, but even in your image it seems to be rather 10% which you loose and not 5%. Many of the users have FreeCAD installed on laptops where space is a very valuable thing.
This Is great!!!!!!Kunda1 wrote: ↑Tue Sep 25, 2018 6:24 pm This discussion which a large portion is IMHO essentially regarding 'scarcity of screen real-estate' reminds me of ickby's awesome proof of concept frameless UI
Could it be integrated in the near future again?
I updated the pic to show that it really isn't that much of the screen, thanks chrisb.
I want to say this screen setup should be used for the beginner that needs to see how things work but the floating windows are rather fragile. I don't know any way to lock the floating windows (tree and combo) in place.
