If you want a thing: Make a reply below clearly stating what it is that you're looking for, the approximate cost of that item, and a concise justification. When someone contacts you via PM and arranges to provide you with the item, edit your post to strike through the original text, marking it clearly as being a completed transaction. To strike through text, use 's' tags, for example to write text, use:
[s]text[/s]
Discussion about the Book Club belongs in another thread - for example FreeCAD Book Club - Discussion.
