Hoping we can have a dwire with plane aligned to active drafting plane.cadgiru wrote: ↑Thu Oct 11, 2018 5:37 am Is this a bug?
A dwire created on a plane other then XY, will still have its Normal in global Z direction.
Dropping the dwire to a wire, the resulting wire will have its Normal relative to the plane the dwire was created on.
Resulting in:
Extruding a dwire will always result in an extrusion in global Z direction.
Extruding a wire will extrude in a z-direction normal to plane formed by wire
Consistant repeatable behaviour in fc 0.17 / 0.18
Any ideas anyone?
regards
Yes, know there are workarounds, however being able to extrude a dwire directly would speed up modelling.
This is a very efficient way to model, when the overhead of a parametric sketch is not needed.
Q) Why do we have the two entity types wire and dwire. Are they not basically the same?
regards
