There is an inconvenience in the workflow between the part design pad and pocket.
In the attachment i have added a plate with an hole... both sketched on the xy plane. the default direction of the the pocket is reversed against the default direction of the pad...
I don't think it should be reversed. You can attach a sketch to a face and the pocket is going down into the material. If you attach it to the principal plane - which is a good idea to make it robust - the "down" direction often contains nothing, so you have to revert it, in order to take material away.
Jee-Bee wrote: ↑Fri Oct 19, 2018 9:37 am
both make no sense to me... still the positive side swaps or it don't swap but is assumed that the direction is negative...
Perhaps this point of view helps clarifying things: padding and pocketing always go in opposite directions.
we could make it guess the initial state of Reversed flag by analyzing the model before opening the dialog. Just how PartDesign Revolution does. And Part Extrude's Make Solid checkbox. This will not affect the robustness, but will reduce the confusion a little bit,
Would it be a idea to add a config option for setting the normal direction for cutting part design features?
in the parameter editor: Preferences>>Mod>>PartDesign ...
