Minor report: Missing small icon in a field.
jruiz
Post by jruiz »
Good morning.
Have you realized that
  1. in Part Design WB, when
  2. "Make a thick solid" (or "Make a draft on a face") is selected,
  3. in the Thickness (or Draft angle) field
  4. the little expression icon is missing?
Regards
I have uploaded many FreeCAD video tutorials to my YouTube channel
Re: Minor report: Missing small icon in a field.
Good point. Can you check if there is a ticket in the bug tracker?
If you need it, you can confirm the feature and use the expression in the data tab.
jruiz
Post by jruiz »
chrisb wrote: Fri Oct 26, 2018 11:18 am Good point. Can you check if there is a ticket in the bug tracker?
Thanks for the information of the data tab.
just reported the tiny little bug.
Regards
issue #3652
The bug reporting process is: discuss here (done!), create issue (done), crossreference forum and bug tracker (done).
sgrogan
Post by sgrogan »
chrisb wrote: Fri Oct 26, 2018 8:44 pm issue #3652
Side note: Work around provided(done)
"fight the good fight"
