Pre-built Debug Builds easier to access for testers (2nd try)
Post by Kunda1 »
Continuing where we left off https://forum.freecadweb.org/viewtopic. ... 7&p=156918
How can we achieve this without creating more work for the packaging team ?
Basically, automating (using TravisCI) to generate full symbol builds for debugging is becoming more essential everyday as we have more people willing to jump in, test and debug. I recently read over on the OSE wiki that ruslan (the creator of the OSE piping WB and contributor to the Flamingo WB) was having issues debugging FC (link) He writes
rus wrote:I tried to find out how to debug FreeCAD. It just does not work :(. FreeCAD crashed. How I suppose to teach someone to program under these conditions?
If it's issues with Travis maybe we can take some of the funds we have in bountysource and purchase a monthly travisCI plan so we get access to extended build times and whatever other amenities come with that...?
We also need a better Debugging tutorial to captivate users to jump in the deep end of development. Right now we provide them with a superficial and tooth-less (no debug symbols) technique.
Paging all participants in the previous thread
sgrogan wrote: Wed Jan 18, 2017 5:44 pm
DeepSOIC wrote: Wed Jan 18, 2017 6:20 pm
NormandC wrote: Sun Jan 29, 2017 10:19 pm
Jee-Bee wrote: Wed Jan 18, 2017 2:19 pm
Related thread:
Discussion: Framework for Automating Builds (buildbot etc..)
rus
Re: Pre-built Debug Builds easier to access for testers (2nd try)
Post by rus »
Hallo @Kunda1,
thank you for your support. I didnt know you read my frustated OSE-log :oops: .
In OSE we want to teach more people to become FreeCAD developers. A proper debugging is very important to me, because lack of it slows down the development process and makes it harder to learn and harder to teach FreeCAD development.
I have tried once more with instructions from https://www.freecadweb.org/wiki/index.p ... =Debugging and got more information
about the issue on my computer
Thread 1 "freecad" received signal SIGSEGV, Segmentation fault.
0x00007fffedd23fcb in XML_SetHashSalt ()[/url]
   from /lib/x86_64-linux-gnu/libexpat.so.1
It looks like it is a known problem
https://forum.freecadweb.org/viewtopic. ... 8&start=10
I hope to finde a solution...
Post by Kunda1 »
rus wrote: Sat Nov 10, 2018 10:21 am
0x00007fffedd23fcb in XML_SetHashSalt ()[/url] Un
Is this the expat version bug ? I think you need to downgrade expat to get this to work. I need to search the forums/tracker
rus
Post by rus »
I think, it is.
This two lines in the console crash freecad:
from xml.dom import minidom
minidom.parseString("")
Post by Kunda1 »
rus wrote: Sat Nov 10, 2018 3:53 pm I think, it is.
Check out https://forum.freecadweb.org/viewtopic.php?t=29913
rus
Post by rus »
IT WORKS !!! :) :)
Thank you @Kunda1!
rus
Post by rus »
Kunda1 wrote: Sat Nov 10, 2018 4:14 pm Check out https://forum.freecadweb.org/viewtopic.php?t=29913
IT WORKS!!! :D :D
Thank you very much!
Post by Kunda1 »
kkremitzki wrote:
Maybe this can be added to the buildbot idea ?
