(solved) 0.18.15248 do not open files correct
user1234
Postby user1234 » Tue Nov 20, 2018 10:42 pm
Hello!
I made a compile now and i can not open files (assemblies). Smaller files seems to work, but larger files not. They worked 0.18.15240 (also i do not changed them). The CPU drives with all cores with 100% and the RAM goes up till FreeCAD dies. I think that a type of element will not load anymore.
OS: Debian GNU/Linux buster/sid
Version: 0.18.15248 (Git)
Hash: 608d42d3cdce307b585534adfdae9c9af7304436
Python version: 2.7.15+
Qt version: 5.11.2
Locale: C/Default (C)
Greetings
user1234
triplus
Re: 0.18.15248 do not open files correct
Postby triplus » Tue Nov 20, 2018 11:36 pm
Hi @user1234
If possible could you narrow the issue down a bit further? As you compile FreeCAD yourself. Could you compile at:
git checkout fc5b6288c6eb4fe89192f63f1fbdf4a43c0fad27
To see if the issue still persist. If not likely a regression was introduced in one of the Sketcher related commits (after Nov 16, 2018).
user1234
Postby user1234 » Wed Nov 21, 2018 12:38 am
this is 018.15221. But i know that worked before. Must a be one of the last 8 commits or one of my dependencies that i updated today. I will compile through the last. The funny thing, that the compiling today gave my new warnings. But i did not save the logs.
edit: i must stop today, will test this tomorrow
abdullah
Postby abdullah » Wed Nov 21, 2018 12:37 pm
If this is confirmed, we will need an offending file, the smallest the better. ;)
PrzemoF
Postby PrzemoF » Wed Nov 21, 2018 1:21 pm
Postby Kunda1 » Wed Nov 21, 2018 2:05 pm
@user1234: did you try git bisect to get the offending commit?
https://www.preining.info/blog/2015/04/ ... made-easy/
https://www.metaltoad.com/blog/beginner ... limination
An aside:
probably a good idea to mention this in a dedicated section on the Github wikipage.
abdullah
Postby abdullah » Wed Nov 21, 2018 4:24 pm
Maybe:
ddfa51056559c70bf8698c79af69eb74a339ba81 works
ddb20468ad438f05c77b02be9b048ace92e8ad6d does not work
In those commits the XML reader was modified to throw an exception is a non-existing attribute is tried to be restored. This should be a feature in the sense that it should help discover problems that were being ignored.
If that is the case, I would really need an offending file to figure out which kind of object/attribute is the one making the mess...
user1234
Postby user1234 » Wed Nov 21, 2018 5:25 pm
Hello!
That thing also thought yesterday because, XML and file loading, that could me a match (whithout a spark of experience from my side). I am compiling (at first ddfa51056559c70bf8698c79af69eb74a339ba81 release mode to test if that works) now, please wait approx 1h. Then i can say more.
Greetings
user1234
Postby user1234 » Wed Nov 21, 2018 6:05 pm
So, thats funny. I compiled one, do not work. So just in case, deleted the userfiles, that assemlies files loads again. I know, i should do that before, i have not. But i did not set up anything since the preselecting uncheck (that slowsdown FreeCAD on assemblies extreme).
Sorry for the noise i made.
Greetings
user1234
DeepSOIC
Re: (solved) 0.18.15248 do not open files correct
Postby DeepSOIC » Wed Nov 21, 2018 6:14 pm
You have a perfect signature of tessellation settings being screwed up. Did your slowdown on large assemblies with preselection "on" go away?
